rear ABS sensor
rear ABS sensor
Wifes 2008 xb is throwing the abs code for both rear sesors. Abs brake vsc and traction light are on. I know its either the harness or the sensor itself but i cant get the wire off to check for corrosion. I got the grey thing off but totally clueless on how the harness comes off. Any help is greatly appreciated. Everything I've read says a screwdriver in the right spot and it pops off. No clue where that spot is
I find it interesting that BOTH rear sensors are throwing codes. did you change tires recently? (make sure there the same size) corrosion seldom effects 2 connectors at the same time. Look under the hood for rodent nest evidence a mouse eating a ABS pump ground would cause dual codes at the same time. what exactly are your codes? On the connector there is a small tab inside the loop/or handle of the connector that needs released.
daniinpitt
04-04-2015 08:07 PM
umnitza
12-01-2014 06:26 PM
