I need Wheel Fitment help!
Old 02-12-2015, 07:09 PM
meechindisbeech's Avatar
Default I need Wheel Fitment help!
Im thinking 18x9 +20 offset all the way around. I already have my fenders rolled.
Will the wheel fit and not rub my caliber/rotor?
Will that fit in the fender or will i have some poke outside of the fender?
Thanks for any info
___
meechindisbeech is offline
Old 02-12-2015, 11:05 PM
Utah Scions
xseveredveganx's Avatar
First inquiry: will the wheel fit and not rub my caliper/rotor? The wheel shouldn't come close to the rotor, but depending on the wheel, it could hit the rotor but it's highly unlikely.
Second inquiry: will that fit (18x9 +20) in the fender or will I have some poke outside of the fender? It's relative to the fender work. I'm positive there will be some poke, but it's not going to be a ton.
I'd recommend a narrow 215/40R18 wrap like Achilles. You should be fine since you already have fender work.
xseveredveganx is offline
Old 02-13-2015, 04:50 PM
MinusPrevious's Avatar
Originally Posted by meechindisbeech
Im thinking 18x9 +20 offset all the way around. I already have my fenders rolled. Will the wheel fit and not rub my caliber/rotor? Will that fit in the fender or will i have some poke outside of the fender?
Thanks for any info
+20 is going to be tough to fit especially in the front. For sure there will be some poke. Rear will be tight as well regardless of roll
Also, minimum tire width for a 9" wheel is a 235. Running anything narrower is not safe & a performance negative.
Rules of tire fitment. Never run out of spec tires & never add out of spec camber to make it fit
MinusPrevious is offline
Old 02-14-2015, 06:34 AM
Thanks for the help man, would 18x9 +35 be any better?
Old 02-14-2015, 06:35 AM
Thanks for the knowledge. Would a 18x9 +35 be any better that the +20? Or is the 9in width in the front the issue?
Old 02-14-2015, 01:31 PM
There a many examples of form / function in this xB2 group. Im function / form!!!
For sure, the +35 would be a better fit than the +20 by far (15mm further inboard)
The 9" wide wheel limits your tire size to a range of 225 to 235 min.
As an example, I run a 235/45 up front on a 8" wide wheel, offset +38 & I am flushed out up front.
The rears have plenty of room
___
Old 02-25-2015, 03:25 AM
alex_prollock's Avatar
I also need help with this. Right now my wheels are 42 offset with 15mm spacers up front (hub centric, not just a plate).
I'm looking at getting some CCW style wheels 18x8 with 35mm offset. Tires I have are 235/35/18 and will fit nicely on the wheel.
Here's my problem, the first 2 or 3 threads on my front lugs have been cut off to accommodate the 15mm spacers.
Is it safe to run the wheels on the cut lugs if since the wheels won't fit with the spacers on?
____
alex_prollock is offline
Old 02-25-2015, 08:14 PM
LophatXB's Avatar
How would an 18x9 -26 front and a 18x10 -20 fit on the xB?
__________________
LophatXB is offline
Old 02-26-2015, 08:10 PM
Greg S's Avatar
Originally Posted by LophatXB
How would an 18x9 -26 front and a 18x10 -20 fit on the XB?
Nope.
For reference here is one of my sets
18x9 +6 Front
18x10 +15 Rear
Both had 1.25" of poke
The specs you posted will be another 1.25-1.5" further out.
Greg S is offline
Old 02-26-2015, 08:14 PM
Greg S's Avatar
Now if those number were supposed to be +26 and +20 then you'll have about an inch of poke in the rear and 3/4" in the front.
Greg S is offline
Old 02-27-2015, 04:45 AM
Utah Scions
Originally Posted by alex_prollock
I also need help with this. Right now my wheels are 42 offset with 15mm spacers up front (hub centric, not just a plate). Im looking at getting some ccw style wheels 18x8 with 35mm offset.. tires i have are 235/35/18 and will fit nicely on the wheel. Heres my problem, the first 2 or 3 threads on my front lugs have been cut off to accommodate the 15mm spacers. Is it safe to run the wheels on the cut lugs if since the wheels won't fit with the spacers on?
No. Replace the studs with extended units.
As Greg already stated, if they're in the negatives, there's no way in hell they'll fit without flares and cutting up your car.
Old 02-27-2015, 11:13 PM
LophatXB's Avatar
Yeah I meant plus not minus. I recall some one on here tried 18x10 on the front. I searched but had a hard time locating the posting. As I continue my search for new wheels.
LophatXB is offline
Old 02-28-2015, 04:20 AM
Utah Scions
18x9 +26 and 18x10 +20 can fit with fender work and some suspension adjustments.
You could get away with a narrow 225/40R18 or a wide 215/45R18.
ThisorThatxD
Scion xD Wheel & Tire
01-06-2012 08:28 AM
sw09
03-01-2011 03:37 AM
justmyluck
Scion tC 1G Wheel & Tire
11-23-2008 01:43 AM
Matsukawasan
04-17-2007 03:40 PM
ayS
13
12-18-2006 12:48 AM
Quick Reply: I need Wheel Fitment help!
