The OFFICIAL 18" Wheel Thread.... Let's see them
Old 11-07-2014, 09:39 AM
  #1261
randomsuper's Avatar
currently i'm running 18x9.5 +35 in the rear but i'm throwing some 20x8.5 +38 wheels on it next week. i want to go out 5 to 8mm more. i just would rather not buy hubcentric spacers.
randomsuper is offline
Old 11-08-2014, 12:36 AM
  #1262
vancouverray's Avatar
I got 19x8.5 +38 on the rear of my 012 XB . 10mm H&R spacers , extended studs too . Don't go with the bolt on ones .
vancouverray is offline
Old 06-13-2015, 11:33 AM
  #1263
ilocano671xb2's Avatar
Heres mine
Attached Thumbnails The OFFICIAL 18" Wheel Thread.... Let's see them-image.jpg
ilocano671xb2 is offline
Old 06-19-2015, 07:09 AM
  #1264
jnaval's Avatar
Haven't posted in a while, here's my xB2 as a refresher.
Attached Thumbnails The OFFICIAL 18" Wheel Thread.... Let's see them-img_6820.jpeg
jnaval is offline
Old 07-10-2015, 04:50 PM
  #1265
Krysune's Avatar
Here my baby... 18" x 7.5 +42
Krysune is offline
Old 07-20-2015, 04:52 AM
  #1266
4150's Avatar
18x8 +30 MB Weapons/A-Tech Erasers in bronze all the way around
4150 is offline
Old 07-24-2015, 09:41 AM
  #1267
undftdxb's Avatar
18x8 +30 MB Weapons painted satin white
undftdxb is offline
Old 08-16-2015, 03:02 AM
  #1268
10spokess's Avatar
Size:  301.9 KBName:  IMG_20150812_204214_hdr_zpsp0ra1srk.jpg
Size:  365.9 KBName:  IMG_20150812_115917_hdr_zpsbptbi5a9.jpg
10spokess is offline
Old 03-15-2016, 06:39 PM
  #1269
nava89's Avatar
Here's how mine looks now ended up cutting the front flares because my front lip broke in three pieces. 18x9.75 and 265/35 all around
Attached Thumbnails The OFFICIAL 18" Wheel Thread.... Let's see them-image.jpeg
nava89 is offline
Old 03-19-2016, 07:40 PM
  #1270
Biggregg24's Avatar
Looks good. Where did u get the flares?
Biggregg24 is offline
Old 03-20-2016, 07:56 AM
  #1271
autobotguy's Avatar
Got myself a set of Avid.1 av-06 wheels in 18x8 wrapped in Fallen Zeix rubber.
Attached Thumbnails The OFFICIAL 18" Wheel Thread.... Let's see them-img_20160228_152034592_hdr-02.jpg   The OFFICIAL 18" Wheel Thread.... Let's see them-img_20160227_220456490_hdr-01.jpeg
autobotguy is offline
Old 03-21-2016, 05:44 AM
  #1272
nava89's Avatar
After hours automotive same guy that made them for the 2jz xb.
nava89 is offline
Old 03-21-2016, 05:45 AM
  #1273
nava89's Avatar
That set up looks clean. Good job
nava89 is offline
Old 04-10-2016, 08:26 AM
  #1274
dean_saldana's Avatar
Hey guys my first time posting here since i just got new wheels. So i bought some zaubers, 18x8 +40 and 18x9 +38. I got 225/40 tires for them and im dropped on df210 springs. I wanted to get 10mm spacers for all 4 sides but i was told i would have to get extended studs. Can anyone point out where to get them? Or do some spacers come with the studs already?
dean_saldana is offline
Old 04-12-2016, 03:07 PM
  #1275
Administrator
Administrator
MR_LUV's Avatar
Dean, I'm not a Wheel & Tire Expert but, you can start by Checking out these 2 sites: Wheel Lug Nuts, Studs, & Spacers | Jegs.com
https://www.z1motorsports.com/z1-pro...ds-p-4215.html
Hope it Helps
Good Luck!
MR_LUV is offline
Old 04-30-2016, 02:06 AM
  #1276
Sinnerxb's Avatar
Hey guys, I just bought my xB Tuesday and I already have trd springs on the way and I need help with wheel size selection, please. I've been through all these pages and I'm not closer in figuring it out, lol.
I already have tires 235/40/18 so I want to run those with the trd drop and I don't want to roll or pull fenders so what width and offset do you guys suggest?
I've decided to get forgestar M14 but I'm not sure if I should be safe and get 8" or 8.5"..... I'm leaning towards 8.5"
Thanks
Sinnerxb is offline
Old 04-30-2016, 01:18 PM
  #1277
GDubya's Avatar
In the front, 18x8.0+38 will be exactly flush, 18x8.5+38 will poke ~1/4".
Depending on tire, 235/40-18 should mount with (very near if not) vertical sidewall on 8.5" wide wheels (eg. 225/40 yields just slight stretch) and afford a bit more curbing protection on 8.0" wide. I'm running 225/40 on 18.0x8.5+38 mTechnica Turbos. And yes, I need to get around to posting pics...
With TRD drop, all of the above will work without rubbing/fender work unless you hit huge bump and/or huge load.
GDubya is offline
Old 04-30-2016, 03:25 PM
  #1278
Sinnerxb's Avatar
Thank you for the reply. I want to run a square set up so I can rotate the tires. So I'll either get all 8" or all 8.5"
Sinnerxb is offline
Old 04-30-2016, 04:47 PM
  #1279
GDubya's Avatar
Agreed on non-stagger for rotation. 12mm spacers (do require swapping studs) will flush/match up the rears.
GDubya is offline
Old 05-01-2016, 04:05 AM
  #1280
Sinnerxb's Avatar
I'm thinking 8.5 with +40 as of now with the 235/40
Sinnerxb is offline
Quick Reply: The OFFICIAL 18" Wheel Thread.... Let's see them
