The UNOFFICIAL 19" thread
#41
Finally test fitted my new wheels on, Axis Pentas 19x8.5" +35 up front, 19x9.5 +40 rear but running 1" spacer to clear caliper in back. Running 225/35/19 front and back.
Changing to a 5 or 10mm spacer next couple weeks, getting rear fenders rolled and pulled. Wheels were powdercoated by Customfunctionz.com in Maryland, dark grey with orange flakes in the clearcoat
#43
finally test fitted my new wheels on, Axis Pentas 19x8.5" +35 up front, 19x9.5 +40 rear but running 1" spacer to clear caliper in back. Running 225/35/19 front and back. Changing to a 5 or 10mm spacer next couple weeks, getting rear fenders rolled and pulled. Wheels were powdercoated by customfunctionz.com in Maryland, dark grey with orange flakes in the clearcoat
Loving the Wheel set up. Stanched and looking really clean, congrats.
#45
Already planned on powdercoating same color as wheels. Im just trying to get everything else done before I worry bout that too.
#50
#51
#52
Does 19x9.5 with 40 offset fit
I'm getting a good deal on some Lorenzo 19x9.5 all around with a +40 offset I'm thinking of maybe putting some 225/35/19 would this wheel clear
I have raceland coilovers with a 2 1/2 drop in the front and 3 in the back
Just asking I'm a newbie to this
It's either those wheels or 2014 tc 18x7.5
What do you guys think
#53
Im looking for a set of 18" or 20" for my 08 Scion XB (stock Heigth).
I was told by the tire shop, that going with 20's, I would have to take every driveway at an angle.
I'm just at that crossroads were 20's might be too big and 18's not big enough.
Im looking for some input on rige quality, handeline etc..
Roger
#54
Did you lower your XB yet?
It looks sweet, but the aspect ratio (with the space from the top of the tire, to the fender), is what I'm trying to avoid on mine.
I haven decided if I wanted to go 19's or 20's
Roger
#55
After installing my Airlift air ride kit, I decided it was time to get some new some new wheels. They're Five AD X5F wheels. They are all 19x8 with a +16 offset after you factor in my adapters (same ones I used for my salad shooters) since these are 5x120. I'm running 215/35/19's all around. The front can go a little lower now that I had the front camber adjusted to -1.
#57
#59
I need help!!! :D
I need help on what size rear spacers to use. Wheels are 19 x 8 all around, 225/35R19 tires. I'm currently not dropped yet. but hopefully soon! Any input /suggestion on what type / brand of springs to use? or possibly coil overs?
Thanks in advance
Thanks in advance
