2008-2010 [ZSP110]
Oil change issue
Old 07-18-2016, 02:11 AM
rkjjeep's Avatar
Default Oil change issue
I've done hundreds of oil changes over a 40 year period. Changed the oil on the 2014 XD last night. Was still a little warm and when I pulled the drain plug the oil didn't simply DRAIN out............it came out as if from a fire house, splattering into the drain pan and then 4 feet out of it. I have never seen anything remotely like this. Where did that kind of pressure come from? Ideas?
rkjjeep is offline
Old 07-27-2016, 11:27 PM
DAlex's Avatar
Plugged PCV. Pull it and clean it or else replace it. Very simple problem to fix.
DAlex is offline
Old 07-30-2016, 04:14 AM
SatsumaxA's Avatar
Agreed ^^^^
SatsumaxA is offline
Old 09-18-2016, 11:26 AM
rkjjeep's Avatar
Thanks for the replies but On a car with 5,000 miles? And I had the oil fill cap off so I don't think it was crankcase pressure.
rkjjeep is offline
Old 09-21-2016, 10:14 PM
DAlex's Avatar
Oil fill cap is on the head. PCV valves rarely fail, but they can be defective.
DAlex is offline
Old 09-21-2016, 11:57 PM
rkjjeep's Avatar
Default oil fill cap
OK, thanks, but I know where the oil fill cap is. When you remove it you release any pressure that might have built up in the crankcase from a defective PCV valve. The area underneath the valve cover shares a cavity (albeit oddly shaped) with the crankcase.
rkjjeep is offline
wlking1688
02-25-2017 10:18 PM
caliscion83
06-26-2016 08:26 PM
Tristanlogd
06-24-2016 05:38 PM
tokyo121
06-03-2016 08:27 PM
BAMF
04-27-2016 05:11 PM
Quick Reply: Oil change issue
