Oil change issue
Oil change issue
I've done hundreds of oil changes over a 40 year period. Changed the oil on the 2014 XD last night. Was still a little warm and when I pulled the drain plug the oil didn't simply DRAIN out............it came out as if from a fire house, splattering into the drain pan and then 4 feet out of it. I have never seen anything remotely like this. Where did that kind of pressure come from? Ideas?
oil fill cap
OK, thanks, but I know where the oil fill cap is. When you remove it you release any pressure that might have built up in the crankcase from a defective PCV valve. The area underneath the valve cover shares a cavity (albeit oddly shaped) with the crankcase.
wlking1688
02-25-2017 10:18 PM
caliscion83
06-26-2016 08:26 PM
