Wheel Sizing?
Old 04-26-2014, 12:50 AM
xceliD's Avatar
Default Wheel Sizing?
OK, so I'm looking at getting some Gram Lights 57C6 for my stock xD 2011,
but I am lost with the whole sizing my stock info is at 195/60R16 and this is the info provided about the wheels:
17''
7J 42 (27) and 50 (26) 5x100
43 (26) and 50 (26) 5x114.3
9J 40 (19) 5x100
HELP!!!
xceliD is offline
Old 04-26-2014, 04:24 PM
XDC
XDC's Avatar
The factory 16" wheels have a +42 offset.
The bolt pattern is 5-100.
I run a 16" after market wheel that has a +38 offset, and I think it looks better because it pushed the wheels outward a tiny bit more. I also considered a +35 offset because it would have looked even better, and still not rub on fenders. But, +35 was not available in the model I picked.
So just make sure the wheels you pick have a 5-100 bolt pattern.
As far as offsets go, I would imagine you should be ok with +35 thru +42, but others here may have better advice with offsets.
XDC is offline
Old 04-28-2014, 10:15 PM
Barfalamu's Avatar
The wheels you're looking at are 17"x7", so basically the same size as the stock tC1 wheels. off set is pretty close to factory, so you'll be fine on clearance.
For tires on that size rim I'd suggest a 205/45/17 or a 215/45/17 to make it look good on the wheels.
As for what tire to run, any that are in your budget, ones that you like. you can even go up to a 225/45/17 if you want.
___
Barfalamu is offline
himynameischris
Scion tC 1G Wheel & Tire
14
01-18-2008 05:17 PM
HR_Guy
12
01-10-2008 03:21 PM
Jackal2k7
07-02-2007 01:21 PM
DannyMiggz
04-07-2007 02:59 AM
bajamike
12-16-2005 02:20 AM
Quick Reply: Wheel Sizing?
