The Be All End All Tanabe df210 Springs Thread!(pics too)
Old Oct 24, 2010 | 05:11 AM
  #361
ChampionJeep's Avatar
I can't compare my spring and shocks to TRD's. I am running the 210's with echo struts and the stock rear struts. Compared to a stock xB I thought it was so much better. The only problem is I wish I could bring the rear down to match the front height. Its a great drop.
Originally Posted by mrsocks
Here's a question that I hadn't thought about before. I have beem considering the Echo struts for my box in order to gain (lose?) the 1/2" drop. My box had TRD springs, shocks, and struts installed when it was new. Does any one know how these THREE compare? In other words I could ask how the Echo struts compare to the TRD's that the dealer put on.
Old Jan 21, 2011 | 03:13 AM
  #362
bdmridgeback's Avatar
210's in mine, 18xalot , 1/4" spacers in the rear, and she sits perfect in my book!!!!
Old May 14, 2012 | 01:34 AM
  #363
dceclipse's Avatar
My XA on df210
Old Jan 14, 2014 | 05:22 PM
  #364
itscurtsk's Avatar
Does anyone know if xB springs are taller than the xA? The xB has greater drop than the xA, but if xB spring are taller then this is irrelevant. However, if it is the same height, I would get the xB DF210s over the xA.
Old Sep 5, 2014 | 02:14 AM
  #365
Geoman's Avatar
What is everyone using for shocks with there DF210s..i have gabriel ultra shocks and struts right now..would i need diffrent ones when i put my df210 springs on?
Old Sep 5, 2014 | 08:20 AM
  #366
itscurtsk's Avatar
many people go with monroes, but gabriel is just another replacement brand. if it is still in good condition, i would just keep it and see how it is.
Old Sep 7, 2014 | 01:49 AM
  #367
Geoman's Avatar
What offset and tires for 16x7's do i need to get to get more flush with outside not sticking out but like 1/2 inch from side of fender with my DF210s on or my other option wheel i liked only came in 17" x 7.5 42mm offset? spacer..shims?
Old Sep 7, 2014 | 03:48 AM
  #368
itscurtsk's Avatar
i'm running 16x7 with +40 offset. the fronts have a 5mm wheel spacer just to clear the calipers and sits near flush right inside the fender. i used to have an 25mm (1 inch) hub spacers in the rear but would rub a little bit of the tire side wall with back passengers when going over dips etc due to the bounce, which is why i took it off. 20-25mm spacers should be fine since DF210s only give a 1.8 inch drop for the rears.
Old Sep 7, 2014 | 04:05 AM
  #369
Geoman's Avatar
16x7 or 17x7? your garage shows 17x7 ..what size tires are you using? did you have to roll fenders?
Old Sep 7, 2014 | 08:09 AM
  #370
itscurtsk's Avatar
i was only rubbing on the rears when i was on 17s with 215/45/17 tires with 25mm spacer. however, i am on racelands, was never on df210s. you will not have any fender issues at all.
Old Sep 7, 2014 | 04:00 PM
  #371
Geoman's Avatar
ty..that help alot..this plus wheel and tire thing was driving me nutts
thank you
Old Dec 10, 2014 | 12:17 AM
  #372
torranosaurus's Avatar
Anyone go with those cheap ebay springs for 50 bucks?
I have a well worn 2006 xb and for some reason, it looks like a 4x4. This is my 9th xb, and I just bought it so have no history on it. I want to get it down some, but it really isn't worth spending like 250 for springs. The car is probably worth 2500 and is my winter beater.
Old Dec 15, 2014 | 11:37 PM
  #373
holdstumt's Avatar
This is the wroooooonnng thread for that. HOWEVER, I wouldn't recommend going the eBay parts route. Always a bad idea.
Old May 11, 2015 | 05:52 PM
  #374
Scarecrow23's Avatar
Default FS: NIB Tanabe DF210's
**NOTE: Can a Mod move this to the correct Forum, can't post in classified - Tnx
Hello,
Since my xB was totaled I have a few items I would like to get rid of:
Tanabe DF210's 'New In Box" (never got to install them) for $200 shipped or $175 local pickup.
Custom fit Car cover for Gen 1 xB (used only a few times) for $85 shipped or $75 local pickup.
**Shipped to lower 48 or local pickup S Bay Area (Silicon Valley, CA)
PayPal accepted, PM if interested
Old Jul 6, 2016 | 04:32 PM
  #375
yymandyy's Avatar
does anyone have pics of a gen2 on dr210's with 19" rims? Are there any issues with the 19" rim? I have been advised twice now to go to an 18" but want to keep my 19s. Any advise/pics would be appreciated.
I have an RS8 currently on TRD springs and want to go lower
kleecker
Jan 9, 2015 02:26 PM
fluxingnation
Dec 26, 2014 04:28 PM
bBOXD
28
Dec 7, 2003 07:08 PM
Besk_one
Oct 16, 2003 07:45 PM
coasterlvr
Oct 3, 2003 09:16 AM
