Go Back   Scionlife.com » Tech and DIY » General Tech and DIY
Register Forgot Password?
General Tech and DIY Info for Any Scion
Reply
Old 08-06-2005, 05:36 PM   #21
Tito_Cruz
Tito_Cruz's Avatar
Tito_Cruz 30/M
Quote:
Originally Posted by toastbox
Quote:
Originally Posted by Tito_Cruz
Oh, thanks! Although, I was actually looking for some kind of "landmark" that I could look for after reseting it to assure me that I did it right. I'm installing a CAI so I'm guessing a power gain would be something to lookout for. I'm guessing that If the engine doesn't run well anymore or my gas mileage dramatically drops...I can tell the ecu didn't reset....???
There really isn't any kind of landmark or anything. But trust me, if you pull that fuse at the beginning, and leave it out until you are done, the ECU will be reset.
Just remember to let the car idle for 5-10 minutes before you drive it. Regarding Gas mileage....most likely your first two tanks are gonna be significantly lower...I say that because when you hear how aggressive the new intake is, you're gonna jamming the gas all the time, and winding it up. I typically averaged about 23-24 or so in town, prior to the intake. MY first two tanks after wards were 20.x But that's because I was shifting at 4-5000 rpm's, not 2800. Once I got over the noise/aggressiveness, the gas mileage went back up to 23 ish.
Thanks! GREAT FEEDBACK!
Tito_Cruz is offline   Reply With Quote
Old 08-07-2005, 07:08 AM   #22
toastbox
toastbox's Avatar
toastbox 39/M
Send a message via AIM to toastbox Send a message via Yahoo to toastbox
Glad to be of help
"Your mom wouldn't approve of the way I drive. "
toastbox is offline   Reply With Quote
Old 08-13-2005, 06:49 PM   #23
Tito_Cruz
Tito_Cruz's Avatar
Tito_Cruz 30/M
Default YAY INTAKE!
I installed mine the other day and used this method to reset the ecu. If I had done it wrong and it didn't reset for any reason the CEL would've lit up right?
Old 08-13-2005, 07:47 PM   #24
toastbox
toastbox's Avatar
toastbox 39/M
I'm pretty sure, yes.
Old 08-15-2005, 09:12 PM   #25
Tito_Cruz
Tito_Cruz's Avatar
Tito_Cruz 30/M
Default wooopieee!
It worked like a charm...it's been running great! I was a little sceptic at first. Now, if there would be a diagram for the tc, I'm sure that would help out future installers alot. THANKS FOR THE HELP EVERYONE!
Old 10-09-2005, 05:35 AM   #26
dp-_-
dp-_-'s Avatar
dp-_- 30/M
can some explain why it's the EFI fuse and not the ECU-B fuse on the tC?
dp-_- is offline   Reply With Quote
Old 02-18-2006, 06:38 PM   #27
NeoXa
NeoXa's Avatar
NeoXa 30/M
Send a message via AIM to NeoXa
Good info, i've tried before but never noticed a difference...but trying it after doing a few more things - def a difference. Good write up!!!
Sponsor: KAMISPEED WWW.KAMISPEED.COM
BILLET DESIGN WWW.BILLETDESIGN.COM
*edit* images are not allowed in sig
NeoXa is offline   Reply With Quote
Old 05-11-2006, 03:43 AM   #28
sciontc313
sciontc313's Avatar
sciontc313 30/M
well i just want to know what EFI fuse # for tC??
other than that very helpful info
SL MEMBER #8793
FLINT MICA CULT FOUNDER
- Kirk
TUNER : LIFE : PASSION
sciontc313 is offline   Reply With Quote
Old 05-13-2006, 05:55 PM   #29
Epitrochoid
Epitrochoid's Avatar
Epitrochoid 47/M
Aewsome post! I just changed to a K&N drop in filter and it caused a CEL. I knew there was a way to reset the ECU without loosing the clock, radio settings and such.
Thanks!!!
"It's not how fast you drive, it's how well you drive fast"
Epitrochoid is offline   Reply With Quote
Old 05-13-2006, 09:32 PM   #30
kustom_play
kustom_play's Avatar
kustom_play 113/M
Send a message via AIM to kustom_play Send a message via MSN to kustom_play Send a message via Yahoo to kustom_play
cool i'll have to pull the fuse when i put in my CAI
good write up
Dating Audrey Hepburn
Best G/F Ever!
"Of course I will help you! I will wear cute garage clothes and bring you beverages on a tray...all while wearing high heels! "
walking around the junkyard stops dead.... HOW DO YOU KNOW ALL THESE CARS AND THEIR YEAR SPANS!
kustom_play is offline   Reply With Quote
Old 07-02-2006, 11:15 PM   #31
jwaggz82
jwaggz82's Avatar
jwaggz82 32/M
I have a tC and I did this twice. I looked at the back of the fuse box for the efi fuse. There are only two 20 fuses so you have to make sure you look at the fuse chart on the top where you got the fuse clips from. Then I took the fuse out and put it back in 20 seconds later. When I turned my car on it did not fix the cel issue. The second time I took it out I cleaned my car and then put it back in. Either it takes a few times to take it out or it has to be out longer. Someone that has a tC I would give it 10-15minutes then put it back in. See if that fixes the problem the first time.
FOR SALE: Scion tC $5500 w/ engine issues but w/ $5k+ in options
(including limited slip, new pads/tires/rotors): Click Here
FOR SALE - PM ME FOR DETAILS:
1.) 2005 Strupp Header that is Jet-Hot Coated!! $250/shipped&insured!!
2.) 2005 S/C Injectors & Stock tC injectors!! (almost new)
3.) Subwoofers & 4ch amp
4.) 2005 Stock tC exhaust (almost new)
jwaggz82 is offline   Reply With Quote
Old 07-03-2006, 01:26 PM   #32
vintage42
vintage42's Avatar
vintage42 14/M
Default Re: ECU Reset Without Disconnecting Battery
Quote:
Originally Posted by mikochu
Here is how to reset your ECU without disconnecting your battery...
On the xA, the EFI fuse is #4:
On the xB, the EFI fuse is #12:
That is from the first post of this thread, and I think the fusebox diagrams are switched (interchanged). The first fusebox is the really xB's and the second fusebox is really the xA's. I don't think anyone has noticed this error yet.
I think the post would be correct if the diagrams were left in the same place and only this change was made:
On the xB, the EFI fuse is #4:
On the xA, the EFI fuse is #12:
Otherwise, my xB has an xA fusebox ;-)
vintage42 is offline   Reply With Quote
Old 07-03-2006, 01:59 PM   #33
Epitrochoid
Epitrochoid 47/M
It's #4on my 2005 xA RS1.0. I had to reset the ECU 6 times after installing a K&N filter.
Old 07-03-2006, 02:56 PM   #34
vintage42
vintage42's Avatar
vintage42 14/M
Yes, I was not correcting the fuse numbers for either car. I was noting that the diagrams were transposed.
How did you know that you needed to reset the ECU even one time??
After I reset my ECU by pulling the #4 fuse, I just started up, warmed the engine for a mile, and then started winding it out in each gear at full throttle. To let the ECU educate itself about 93 octane, supposedly.
It accelerated so violently in 2nd I couldn't find the little tachometer in time to avoid 6000 rpm LOL.
Old 07-03-2006, 03:20 PM   #35
Epitrochoid
Epitrochoid 47/M
[quote="vintage42"]
Itquote]
When I added the K&N it would throw a CEL (check engine light) which also deactivates the VSC abd ABS. Because the K&N is oiled the oil gets on the MAF and causes the CEL. After about 5 resets and spraying electronic cleaner on the MAF sensor the CELs went away.
Anytime you add an engine, intake or exhaust perfromance part you should reset the ECU.
Old 08-28-2006, 01:53 PM   #36
8BALL
8BALL's Avatar
8BALL 60/M
Send a message via AIM to 8BALL Send a message via Yahoo to 8BALL
My VSC, Trac Off and Check Engine lights came on today for no apparent reason. I pulled the fuse for one minute replaced it and started the car and all is well. Great write-up.
8BALL is offline   Reply With Quote
Old 08-28-2006, 02:39 PM   #37
techick
techick's Avatar
techick 25/F
Send a message via AIM to techick Send a message via MSN to techick
I have to agree it was a good write up. Does anyone know what makes the car do this though??
Scikotics Orlando Chapter OSB and OSW
Scion xA RS 1.0
techick is offline   Reply With Quote
Old 09-08-2006, 09:30 PM   #38
B_tC
B_tC's Avatar
B_tC 28/M
http://www.facebook.com/brianpalting MANMEATO
Send a message via AIM to B_tC
can someone clarify what fuse to take out for the tc? after installing my CAI, my car still feels the same as stock... will pulling out the fuse help fix it?
VANESSA
B_tC is offline   Reply With Quote
Old 10-20-2006, 04:47 AM   #39
pimptc
pimptc's Avatar
pimptc 28/M
yes please verify what fuse # it is that you pull out of the tc
*megan header back exhaust
*TRD axelback
*K&N intake
*UR lightweight crank pully
*Greddy air diversion pannel
*self painted color matched accessories(power steering,washer fluid, fuse box)
*black twin halo projectors
*20% smoked tyc tails
*s2000 antenna
pimptc is offline   Reply With Quote
Old 10-20-2006, 06:45 AM   #40
pimptc
pimptc's Avatar
pimptc 28/M
ive also heard that if you have your stock headers cat, to knock out a piece of the catalyst and put it between the 2 antifowlers, but sense i dont have the cat, would there be anything else that could work just as well as the catalyst?
*TRD axelback
*K&N intake
*s2000 antenna
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
06, 2004, battery, disconnect, ecu, efi, fuse, location, relay, reset, scion, sion, tc, toyota, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
