Dezod Housekeeping...website, turbo kits & Aplha kit
Old Mar 24, 2009 | 03:30 PM
paul_dezod's Avatar
Scionetics
KAD
Ok. More updates on the housekeeping:
We are revamping the entire tC catalog for easier use, with MORE products and services. This has been cumbersome, but please bear with us while we get this done.
Old Mar 24, 2009 | 03:31 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by RSracer
T4 ?
Can't disclose information on the build. At least at this moment.
Right now, I can tell you that we have Chase's 08 TC undegoing some mods, the shop's 08 xB is being prepped for it's boosted days and our newest kitten an 06 tC 5 speed is off getting some much needed TLC before we bring this community to the dark side.
Old Mar 24, 2009 | 10:49 PM
chintastictc's Avatar
i would have waited till about a month before the kit will be released before saying anything about it...ur just gonna make people crazy
Old Mar 25, 2009 | 07:59 PM
paul_dezod's Avatar
Scionetics
KAD
tC section is close to done on transformation. Check it out let us know what you think!
http://www.dezod.com/cat_scion_tc.cfm
DEFI gauges will be added up VERY shortly.
Old Mar 25, 2009 | 09:20 PM
scikotictc232's Avatar
any teaser pics at least ?
Old Mar 26, 2009 | 02:17 PM
paul_dezod's Avatar
Scionetics
KAD
Nope.
Old Mar 26, 2009 | 10:43 PM
y do i have a gut feeling its a top mounted twin scroll setup? idk just thinking of what hasnt been seen yet..
Old Mar 27, 2009 | 12:36 AM
Temperz's Avatar
no tea ;( I wanted to go boost but don't have the huge heap of cash to throw down on a kit so I was going to try a custom setup, and was wondering what components are needed for stage 0 so I can run like 6lbs and start from there.
Old Mar 27, 2009 | 12:38 AM
^ save the 6lb no intercooler set up. just save up and do it right the first time. you were probably planning on running untuned ?
Old Mar 27, 2009 | 12:41 AM
Temperz's Avatar
^ ya u can run untuned below 6lbs I think
Old Mar 27, 2009 | 01:48 PM
paul_dezod's Avatar
Scionetics
KAD
No true unless you want a blown motor.
You can not expect to add forced compressed air without adding fuel and adjusting spark accordingly.
Old Mar 27, 2009 | 02:15 PM
Troys_tc's Avatar
I do belive that you are very true when it comes to running a t-series turbo, but there are plenty of expamles of 16g and 20 g based turbo's running 6 or more pounds of boost with out any problems, I have had my kit set at 6 pounds on my 16g for 10,000 miles with no problems, other than blowing 2 manifold gaskets becasue being un-tuned does raise the E.G.t.'s tosometimes 1700+ degrees
Old Mar 27, 2009 | 03:02 PM
paul_dezod's Avatar
Scionetics
KAD
Iother than blowing 2 manifold gaskets becasue being un-tuned does raise the E.G.t.'s tosometimes 1700+ degrees
Examples of luck and nothing more. Other than 2 blown head gaskets.....That is from detonation my friend. That is the cause of 90% of blown motors if not more.
Old Mar 27, 2009 | 03:05 PM
Troys_tc's Avatar
Correction not head gaskets, exhaust manifold gaskets are what I have blown
Old Mar 27, 2009 | 05:14 PM
Temperz's Avatar
if paul says I should tune I will tune. haha
Old Mar 27, 2009 | 05:54 PM
vettereddie's Avatar
Can I haz more 1NZ-FE stuff plz? head studs and a proper head and manifold gasket would be a great start. I know the xA / xB is out of production but there has to be some interest from the Yaris community.
Old Mar 28, 2009 | 01:45 AM
Troys_tc's Avatar
don't get me wrong paul knows this shi t, and I have alot of respect for what he says, because he preaches the truth, but I was just stating a fact that the smaller mitsu turbos that some members of the scion comunity run me included can be run at low boost "un-tunned", I belive that the zpi kits aren't the greatest, so I do have a 1 off 16g kit that I had made that fixes alot of problems the zpi kits have, including the fact the zpi kits and most other kits out there are not blow thru, which is great to have.
Paul quick question is this kit going to be blow thru??? because I am looking to get a bigger kit so I can do some real damageon the dyno with some big numbers
Old Mar 28, 2009 | 01:48 AM
aen's Avatar
aen
i was on 5 pounds for about 20k miles with no management system at all
and i have a garret 60-1.
the ecu adjusts for us
Old Mar 30, 2009 | 02:13 PM
paul_dezod's Avatar
Scionetics
KAD
New kit will be standalone based for engine management, so MAF placement will be irrelevant.
Old Mar 30, 2009 | 05:18 PM
rhythmnsmoke's Avatar
Music City Scions
That's more that luck. He's not the only one out there you know.
