Raceland Coilover Review for the xA
Old Jul 3, 2012 | 06:51 PM
hmc2261CT's Avatar
yeah i agree but like i said before, i need to put winter tires on in a few months and i wont have the tie to redo my suspension.
but here is the pic you requested, its hard to see, but it is about an inch.
and yeah id like to see the difference, i will be taking out the extra pieces next summer, this summer is just too busy, once it is done, and i get those spacers, im pretty sure my tires will be tucked which will look good
this pic is from when i first put the coilovers in so they are not settled which is why the gap is big
Old Jul 3, 2012 | 08:30 PM
itscurtsk's Avatar
it's hard to get a picture of the helper spring fully compress on the car. there is a picture of it in his first post. it is the thin looking spring at the base of the strut.
Old Jul 3, 2012 | 08:43 PM
xAxAxAxA's Avatar
Is that it? And how hard is it to remove? I see the whole thing comes pre-assembled so you'd need to take it apart to remove it?
Old Jul 3, 2012 | 10:21 PM
itscurtsk's Avatar
you know that racelands don't come with top hats. i'm assuming that the springs are not compress when you get them. the assembly is the same as regular springs and struts. after removing the helper spring, i'm not sure if you will still need a spring compressor to get the top hat on.
Old Jul 4, 2012 | 01:33 AM
xAxAxAxA's Avatar
Not quite sure all that explanation was needed lol, but no the springs don't appear to be compressed when shipped (that would be hazardous). I plan on leaving everything stock for a couple months to have them settle down before modding them. The last thing you want is having some manufacture defect occur while you already modded them -___-
hmc2261CT: 0 offset is the way to go in the back with 20 in the front like austin's xA, for perfectly flush fit. I wouldn't recommend 45mm spacers though lol If you can get in touch with Austin, he was thinking about a new rim setup a while back.
edit: you also may want to roll fenders if you go the low offset route, Austin had to and I'm sure I will too :/
Old Jul 4, 2012 | 03:28 AM
hmc2261CT's Avatar
Yes that is the correct part, and it is very easy to remove, curtsk is right they do not come with top hats and nothing is under any load, so all you need to do is remove the top nut and pull everything off, its so easy a caveman could do it.
as far as getting the top hat on, when i put the struts on the lowest setting they could go, there was no need for spring compressors, in front or rear i did not even touch mine.
the front goes togeather so easy and when you remove the helper spring i can garentee that the main spring wont even be touching the top of the perch, you will need to compress the strut for the spring to touch the top hat.
and xaxaxa: im an happy with the wheels that i bought so i dont think i will be changing them, but unfortunatly i did not know how the large offset would look on my car, In my opinion, it does not look bad. when I was talking before about getting spacers, i would be looking at a 20 mm spacer in the rear and a 10 mm in the front. we are lucky that in the front, the fender lip is so small there really is no need to roll them, however the rear is a pain. I was looking at getting my fenders rolled in the rear, but unfortunately before I bought my car it had been in an accident. There is bondo on the rear quarter pannel (the rear fender) on the passenger side so rolling them would cause the bondo to pop out and then I would have even more headaches and would have to spend more money.
Old Jul 4, 2012 | 06:36 AM
xAxAxAxA's Avatar
Dang... super headache... We'll see how 0 offset fits then :/ I'm still debating whether or not to do the mod now or later...
Full LED conversion coming soon as well
Old Jul 4, 2012 | 10:33 AM
hmc2261CT's Avatar
If you have snow tires that will fit in the wheel wells, do it now, it saves hours, it will be worth it
Old Jul 5, 2012 | 06:57 PM
xAxAxAxA's Avatar
I live in the South haha, but I'm gonna leave it stock because I want to see how the rims fit since I don't have them in yet. And I need to judge whether I can get into my driveway haha
Old Jul 5, 2012 | 08:27 PM
hmc2261CT's Avatar
Yeah your lucky, I live in upstate New York (aka the arctic) so I need to worry about that stuff.
and yes I was worried about that to, everytime i go over a speed bump, i hold my breath and pray, so far iv been lucky!
Old Jul 6, 2012 | 01:31 AM
xAxAxAxA's Avatar
Hahaha you're not QUITE that low... hopefully I'll be good too...
Old Jul 6, 2012 | 01:35 AM
hmc2261CT's Avatar
yeah but you should see some of the speed bumps in Ct and at my college, they are a bit overkill
But hopefully you or I wont have any issues
Old Jul 9, 2012 | 10:45 PM
xAxAxAxA's Avatar
I'm referring to my friend who has a civic em2 less than an inch off the ground hahaha. Good times riding in his car.
Anyways I got my Racelands today and will post the pics after I mod the front coils. Everything looks to be in good shape other than one of the front coils with the bolt off and in the packaging... makes it easier to remove the helper springs I suppose...
Old Jul 9, 2012 | 11:23 PM
xAxAxAxA's Avatar
Helper springs out. I could literally compress them fully with my own hand... completely useless lol.
What exactly are the hook looking things used for?
Old Jul 10, 2012 | 01:35 AM
hmc2261CT's Avatar
Nice!, Hope the Install goes smoothly.
And the three metal hooks are the tools for adjusting the ride height once the suspension is on the car. they are very important so dont lose them! haha
And I did some research on the helper springs, they are actually important. It turns out that they are what keeps the top of the spring seated in the metal car that is right under the top hat. So if you went over a bump and it was large enough to cause the suspension to extend enough, without the helper spring you are running a higher risk of having the spring lose its seating...which would be very bad. so thats another reason why I want to keep mine in (at least for now)
and just a note: The rear springs, the closer wound section goes closer to the ground, I found out I put mine in upside down, it does not matter but im just giving you the heads up since I made the mistake.
Old Jul 10, 2012 | 08:51 AM
itscurtsk's Avatar
without the helper spring, you can't adjust the height of the fronts right? xAxA run it without the rear perches too ;]
Old Jul 10, 2012 | 05:43 PM
xAxAxAxA's Avatar
I'm going as low as I can with these, so I won't be putting in the rear perches.
I see what you're saying with how the helper springs are important, but I'll have to see how much air I'll have to get to unseat the springs... That'll come once I put them on. The other worry is the fact that there's only an inch of spring (uncompressed, and maybe 2 inches) til the bump stop starts... Hopefully I don't run into problems with that or I'll have to shave some of it off... Hopefully the spring will compress enough so that I can get a couple inches or air without having to worry about the spring getting out of place. Bridges around here have awful bumps...
As for the rear springs, or any spring for that matter, the lettering should always be right side up (so you can read it). That's what I've been told.
Lastly, can you explain what parts you had to reuse in the install? I want to be clear when I'm installing... Thanks and I'll be installing these Thursday afternoon with 4 other friends so it should be a piece of cake. (fingers-crossed)
Old Jul 11, 2012 | 03:39 AM
hmc2261CT's Avatar
yeah sure, for the fronts, you need to use the stock tophats and hardware to mount the strut. In the rear, you just need the hardware, the rubber gaskets to help seat the spring, and the dust covers to cover the shock.
thats it!
And yes, hopefully everything goes well, it took me 4.5 hours but I was by myself and was taking my sweet time, you can probably have it done in three if you have enough jacks and jack stands
you should try to PB blast as much of the hardware as you can today and tomorrow so that hopefully when Thursday rolls around everything will be easy to take off
Old Jul 11, 2012 | 03:40 AM
hmc2261CT's Avatar
and itscurtsk, you still can adjust them
Old Jul 11, 2012 | 04:08 AM
xAxAxAxA's Avatar
thats it!
Cool. My car has been a garage queen for 90% of it's life and has never seen salt so all my undercarriage is in fairly good condition, so I'm gonna pass on the PB blast :/ (I also don't have any... lol); however, thanks for the info on what to leave. I'm trying to get in touch with Austin as to how secure he feels the front sits without helper springs and if he had to cut the bump stops, but I have a feeling I will be experimenting with this myself... I'll post pics of the install and my review Thursday night or sometime Friday.
