My last rotary project/project... 3 rotor RX-7
Old Sep 5, 2012 | 01:38 AM
Herblenny's Avatar
Again, while I was waiting on the shell..
decided to shave off the casting seams and paint the Upper intake manifold of the engine.
I was going to powder coat it red.. but thought i give the similar gray black look
and inserted a carbon fiber to tie the whole car together
Old Sep 5, 2012 | 05:06 AM
XIEmperorIX's Avatar
love it
Old Sep 5, 2012 | 11:55 AM
Herblenny's Avatar
Originally Posted by XIEmperorIX
love it
Thank you!
Old Sep 5, 2012 | 11:56 AM
Herblenny's Avatar
While I was doing all that, Goolsby Custom was busy doing these things..
Cut the rear flare.
Installed both my FEED wing and the tail light lip cf spoiler.
Old Sep 5, 2012 | 04:20 PM
Herblenny's Avatar
While the car was at the paint and body.. I continued what I can at home..
Test fit the intake manifold to the short block..
Than I disassembled my throttle body and painted to match..
I also painted my GREX/Alcon calipers.
but one of them needs to be refinished...
Sand blasted by suspension pieces and bead blasted..
And pushed the old bushing out and I accidentally broke one of the arm as I was going on little sleep and rushing the work..
And installed my new Powerflex bushings! I got the Powerflex bushings because they are well made and heard great things from people who used them.
Old Sep 6, 2012 | 01:17 AM
Herblenny's Avatar
Here is something rare for the car..
Defi Super Sport Cluster.. very few in usa and I should be one of the first to put this in an FD here in USA.
I been wanting to get this for about 8 yeears and Defi never sold this here and never sold this off the shelf in Japan. It was specific Dealer only unit in Japan where it had to be installed in a car by the authorized installer in Japan. All the ones that are here in USA were used units and this is a brand new unit.
Old Sep 6, 2012 | 03:37 AM
Herblenny's Avatar
More goodies..
Stance Pro Comp 3 coilovers.
Old Sep 6, 2012 | 01:48 PM
Herblenny's Avatar
Wheels and tires that are going on this car..
WORK CR Ultimate, 18x9.5 front and 18x10.5 rear.
TOYO R888 tires, 255/30 front and 295/30 rear
Mounted and load balanced. I already test fit this set up and tested for speed on my other RX7.
Old Sep 6, 2012 | 02:52 PM
sosborne's Avatar
other rx7??!?!?!
im jelly
Old Sep 7, 2012 | 01:31 AM
Herblenny's Avatar
Originally Posted by sosborne
other rx7??!?!?!
im jelly
LOL! Yes.. I'm a huge rotary fan...
Here is my other one
Mint 1994 SSM that I'm putting all rare Mazda/Mazdaspeed goodies on.. Original paint with only 32K miles. This is my long term project that I been collecting parts for over 7 years... Once done, this would be the most expensive project I have done. Which is kind of surprising since most will think 3 rotor project is..
Old Sep 7, 2012 | 01:33 AM
Herblenny's Avatar
During this build, I had a chance to go visit Chris Ludwig from Ludwig Motorsport to check on the harness for the engine.
We decided to use the AEM coils with the Haltech PS2K.
Mil-spec connector..
Old Sep 7, 2012 | 11:35 PM
Herblenny's Avatar
Sand blasted again and re finished the brake caliper.
Old Sep 7, 2012 | 11:38 PM
Herblenny's Avatar
Here is something new for the 20B that I'm debuting..
ITs the new Xcessive Engineering lower intake manifold for the 20B. This is made for those interested in doing 3 rotor swap on RX7s, by lowering the height of the manifold and also each runner has an individual injector port. By using this, I'll be running 6x ID2000s on this manifold and 3x ID1000s on primaries on the irons. This much fuel, I'll be good for E85, 1000+WHP.... but shooting for 700-800 ish WHP.
I also studded the LIM and cut various FD hardwares to get this studded look with chrome hardwares. Also, better view of the LIM with UIM.
Old Sep 8, 2012 | 04:51 PM
only 700-800whp huh? Trying to be conservative I see lol
Old Sep 10, 2012 | 03:15 PM
Herblenny's Avatar
LOL! we shall see.. I have enough to push 1200 but that's quite difficult
Updated pic of the engine as I started putting things on to make sure things are fitting..
Old Sep 10, 2012 | 03:19 PM
Herblenny's Avatar
My off time past week, I was fabricating a blank cluster surround so I can retro fit my Defi cluster.
about 50% done and going to make a mold once its smoothed out, primered, painted, and then make it in CF.
Also, AC panel
and shifter panel
Lot of sanding fiberglass but hopefully all will be worth it at the end..
Old Sep 10, 2012 | 03:20 PM
Herblenny's Avatar
Couple of detail views of the turbo manifold.. that I didn't post.
And some of the random goodies that are going in in this car..
Aluminum rack..
Carbon Shaft.
FEED trunk thingy in carbon
Old Sep 14, 2012 | 01:12 AM
Herblenny's Avatar
Sept 13th, 2012
I finally took some time to work on the rear diffs of the FD RX-7s.
Here are some pics of the diffs.
Stock vs Kaaz
After cleaning the case, sanding it down, and re painting it with epoxy paint,.. I put the new covers on.
Stock vs. Greddy higher fluid capacity cover.
Old Sep 17, 2012 | 03:12 AM
Herblenny's Avatar
Sept 16th, 2012 - Little bit more update...
Took some time getting the transmission painted and such.. Some color scheme.
and becoming a master of taping
Also, plugged the oil metering hole
and another angle of the painted diff..
Old Sep 20, 2012 | 01:23 AM
Herblenny's Avatar
Sept 19th, 2012 Updates from past 3 days..
I had the rotor hats made for the Disc Brakes Australia rotors and got them refinished in similar black.
Cleaned up and repainted the RZ calipers.
I also replaced the diff bushings with Powerflex bushings.
