Small Questions Thread (Use this instead of creating new threads)
Old May 13, 2013 | 11:15 PM
  #621
Vladislav's Avatar
Originally Posted by simplytc
Is there a labeled diagram of an 06 scion tc engine? There are a bunch of hoses, wires, and other small parts i want to replace but i dont know what they're called.
if you find this out let me know i am in same pickle of my 08
Old May 29, 2013 | 03:29 PM
  #622
Tshock's Avatar
How much should I pay for a used hvac cluster with trim/radio cover/vents?
How much should I pay for a used manual shift bezel/trim/12v housing with clips?
Are there any oem or aftermarket carpet options besides salvaged?
Old May 29, 2013 | 06:34 PM
  #623
itzallgood707's Avatar
How big is the diameter opening of the intake manifold where the throttle body connects?
Sent from my SGH-T989 using Tapatalk 2
Old Jun 10, 2013 | 01:41 AM
  #624
BUMP
Sent from my SGH-T989 using Tapatalk 4 Beta
Old Jun 10, 2013 | 10:34 AM
  #625
Vladislav's Avatar
BUMP
On my 08 tc1 I believe it's 2.5" as it fits my trd intake
Old Jun 23, 2013 | 10:44 PM
  #626
So is the diameter of the throttle body smaller than the opening on the intake manifold?
Old Jun 28, 2013 | 11:48 PM
  #627
Cisco_TeamShogun's Avatar
Is there a thread for "sales" you find online? Or a Bargain thread?
wanted to post this on it:
http://forums.vwvortex.com/showthrea...s-farmas-cheap
the VW crew seperates their sale threads by bolt pattern, most sellers list their tele number, and are willing to ship, so an account is not truly needed. Saw good stuff there, plus a lot of PA guys.
Old Jun 29, 2013 | 12:03 AM
  #628
this does not answer the question, but try http://www.rockauto.com/ and you can go through the section of the car in question, i.e. engine and start looking at parts etc (they do have diagrams).
https://techinfo.toyota.com/techInfo....toyota.com%2F
http://scionlife.org/Scion_Docs/2006_Scion_tC_om/
http://www.club-tc.com/threads/engin...ications.1325/
http://www.toyotapart.com/Scion_TC_Manuals.html
I'll keep looking and keep posting, my eyes hurt
Old Jul 10, 2013 | 10:37 PM
  #629
tC2k10's Avatar
will these center caps fit the tC1's OEM 17" rims?
http://www.ebay.com/itm/161057615381...84.m1439.l2649
Old Jul 11, 2013 | 01:48 AM
  #630
Yes, your listing says 57mm inter diameter. Per this site: http://www.centercaps.net/caps/detai...tockNumber=108
it notes the diameter of 2.25" which is 57.xx in mm. so i would say yes.
https://www.google.com/search?q=2.25...ient=firefox-a
Old Jul 11, 2013 | 03:56 AM
  #631
tC2k10's Avatar
Thanks a lot! I just bought them so I'll confirm it when it arrives haha. Thanks for the help
Old Jul 11, 2013 | 10:16 PM
  #632
tC2k10's Avatar
Update on this, they arrived today, they're too big and wouldn't fit
Old Jul 15, 2013 | 04:33 PM
  #633
*** now I feel bad *edit just red that they are to big.
how much bigger are they? is like a massive amount?
can you remove the ring inside or shave the clips a bit to make it fit?
Old Jul 15, 2013 | 05:32 PM
  #634
tC2k10's Avatar
I debated on cutting it down to make it fit, but that's a lot of work. I'm going to send them back today and get other ones that should fit. It's 57mm clip to clip, OEMs are 57.15 mm diameter across the face of the cap. Should've read that before buying
I did find other ones that I want, but they are 57 mm and OEM is 57.15. Will that .15mm make a difference in fitment, or is it pretty safe to assume they'll fit? I contacted the seller and he just said to measure my OEM ones to make sure. It says it'll fit '06-'10 Toyota corolla and '07-'10 Toyota yaris
Old Jul 17, 2013 | 02:36 PM
  #635
so the ones you bought were 57mm inter diameter
OEM is 57.15 across the face so the clip to clip of the EOM is what ? 54mm? same as the hub right?
is the seller going to let you exchange them? if so thats good.
mesure the OEM ones (clip to clip) to ensure.
the HUB of the rim/wheel is 54.1 so maybe the inner clip size should be 54.1 as well? i am confuse now.
so cuz i feel bad if the seller dont accept, lmk and I can possibly buy from you as a way to make this right since I did say it would fit. Should had remember that the hub size is 54.1 so maybe the inner clip should measure 54.1 instead of 57 (57 is the face right)?
Old Jul 27, 2013 | 04:33 AM
  #636
tC2k10's Avatar
Right, it should be 2.25" (57.15mm) across the face of the cap, and 54.1 clip-to-clip i believe. Thanks for the help. And this one is more of an opinion question, should i get normal-sized or extended lug nuts for the OEM rims? Both lugs are black and mag-style.
Old Sep 7, 2013 | 07:35 PM
  #637
Trixy's Avatar
I'm new in here and cannot figure out how to start a thread so thought I'd try here and hopefully get some feedback in my 06 TC.
I don't know anything about cars so please speak in girl terms. Lol
I just bought a 2006 tc and this car is bad ___, I am in love after a few days.
Okay, the engine fan does not work and the previous owner "rigged" it to where its connected directly to the battery. Tis is a problem being my car sits on the ground and bounces a lot causing the connection to come undone. So I almost over heated it in the freeway yesterday being I didn't know it had turned the fan off. Also, I do not want to cease my engine. I haven't taken it in because I just dint have the cash for it. The fuse was mentioned to me as we'll.
Any thoughts?
Old Sep 8, 2013 | 02:36 AM
  #638
Has anyone here ever swapped out an OEM rear sway bar from an automatic to a manual? My understanding is that manual rear sway bar is 18mm vs. automatic rear sway bar at 20mm. Also I believe the TRD is only 19mm.
Is there any significant difference in ride quality or a decrease in body roll?
I'm cheap and looking for a inexpensive mod to do or I would go with a Progress rear sway bar.
Sent from my Nexus 7 using Tapatalk 4
Old Sep 8, 2013 | 11:14 PM
  #639
Bump
Sent from my SAMSUNG-SGH-T989 using Tapatalk 4
Old Nov 27, 2013 | 05:23 PM
  #640
Taintstick's Avatar
TRD is 22mm...i cant speak with any certainty for the auto versus manual bar but i highly doubt toyota would do something like that, it doesn't make any sense...
