Antifouler / CEL Fix for Header
I know that! I am a automotive technician and have been for 7 years. I have tried simulators several different kinds. The best luck I have had was the Zpi sim and it still didn't work. Zpi worked with me on it and we could not come up to a logical reason why. The problem is there is a voltage spike in the 02 sensor at 4000rpm. Even on a stock tc the voltage spike shows a little just not high enough to set the cel. If you want a permanent fix go to a exhaust shop and get a o2 bung welded in behind the cat on the midpipe and relocate the o2 sensor and you won't ever have a cel from the aftermarket header.
yes, there has to be another factor. i still have my CEL after the anti-fouler mod. i've checked my work twice and even got a couple of friends to do the same. still we cant find anything wrong. somethings jacked up.
and how do u get 290 miles on a full tank? even if your gunnin it sometimes. wow!
I was very much enjoying my new mod
Mods, please sticky or please consider a DIY section. I'm going to put together a quick "taking out the backseats for dummies" as well, and probably my own version of GFI.
If you are lazy and want to find the "HELP" defouler online, I found it as a brand called Motormite, with the same part numbers. I have another question though, is the connector on the rear o2 harness a generic square 4 wire plug? I am planning on buying an extension harness from summit racing and then relocating the rear o2 sensor behind the cat on the draxas exhaust. That wasy I shouldn't need to fool anything.
I have the DC header and K&N intake, and the anti fouler method worked until I hit somewhere between 80-95 mph on the freeway. Im going to add another unmodified antifouler to the ones I already have on there to further remove the O2 sensor from the exhaust stream and will see if this will help my problem. It will look like this.
02 sensor opening in s pipe - unmodified antifouler - unmodified anti fouler - modified anti fouler - O2 sensor .
Im hoping by adding an additional gap, there will be less air going to the sensor and I wont trip my cel.
hey toyota_scion_tc, You have the zpi s-pipe on your tC right? I read on the zpi s-pipe veview, that the zpi s-pipe because the o2 sensor sits back farther on pipe itself that it wouldn't be necessary to do the anti-fouler trick is this incorecct?
yeh my anti-fouler doesnt work either..i have AW header, Injen CAI, and stock everything else. i was thinkin mayb if i get an s-pipe to get more air flow then it might work..but first imma try to add another link to the anti-fouler to make it 3 instead of two. my bro said that might work
well for me the CEL didnt come on until mayb 285 miles after ecu reset. i did this two times so i know its around that mileage. dunno bout you though. mayb wait til after 300 miles? keep me posted because i dont think it will show up right away. weird how urs comes on when u hit 85 mph though. that didnt happen to me..
Originally Posted by English
Is there enough room down there for an extra anti-fouler? From what I remember it was a pretty tight fit when I installed mine
Team No Limitz
I also have the K&N CAI, DC Header and the anti fouler didnt work for me either. I am waiting on the peice from MM to try and see if that fixes it. I will let everyone know on that peice, if it works for me.
will I added an extra anti fouler, and it worked. took the car up to 95mph and the cel light didnt come on. The only problem is that I think it is rattling against some other metel piece when I accelerate, because I hear a little tapping noise that I didnt use to hear before. I will fix this however by just padding the antifoulers so that if they hit something, it wont make a tapping sound.
I got my ZPI Midpipe in its bolted on with the Magnaflow 12646 resonator. Sounds really great. I have the factory header on still. I am waiting to get my 2.5" Stainless steel flanges for the Magnaflow 43036 cat I am going to put in. I am flanging it incase I have any problems with this cat or go turbo later and decide to remove it. I have a complete 2.5" stainless exhaust on my car now it sounds great. My sound shouldn't change too much when I put the alphawerks header back on b/c I will be adding in the catalyic converter on the midpipe.
