Transmission Flush (Manual, Redline MT-90)
Old 12-31-2006, 03:51 AM
  #201
nyr197's Avatar
Originally Posted by Fredzy
I found a place that sells Redline 75W90 NS online,
http://www.hrpworld.com/index.cfm?fo...action=product
I buy my MT-90 through that website. Excellent site.
nyr197 is offline
Old 12-31-2006, 05:04 AM
  #202
web
web's Avatar
^^great site and great product
web is offline
Old 12-31-2006, 04:27 PM
  #203
Fredzy's Avatar
In my owners manual it says GL-4 or GL-5 in the back, but somewhere else it said only GL-5. I figured GL-5 can't hurt... I'll do anything to speed up those synchros...
Fredzy is offline
Old 12-31-2006, 05:39 PM
  #204
web
web's Avatar
GEAR AND SYNCHRONIZER WEAR PROTECTION
Most manufacturers of manual transmissions and transaxles recommend an 80W or 90W GL - 4 lubricant. GL - 5 gears oils which are required in hypoid differentials are not used in most synchromesh transmissions because the chemicals used to provide the extreme pressure protection can be corrosive to synchronizers, which are commonly made of brass or bronze. Typically, the use of a GL - 5 lubricant in a synchromesh transmission will shorten the synchronizer life by one half. The extreme pressure requirements of spur gears and helical gears found in transmissions are not nearly as great as found in rear-wheel drive differentials. A GL - 4 lubricant provides adequate protection for most manual transmissions, unless a unique design consideration requires the extra protection of a GL - 5.
http://www.racerpartswholesale.com/redtech4.htm
I would stick to GL-4 since it's designed for more use in synchroed tranys rather than just differential gears.
web is offline
Old 01-25-2007, 09:13 PM
  #205
tctrs1's Avatar
This is a very helpful tech guide, thank you!
tctrs1 is offline
Old 02-19-2007, 09:23 PM
  #206
Streeter's Avatar
This should be in the tech area - so next time I have to explain to Toyota tech what they're supposed to be doing I can find it easier.
Streeter is offline
Old 03-24-2007, 08:14 PM
  #207
ScionSean's Avatar
Great writeup!!! This question may have already been asked or may not have, I just didn't want to read through 11 pages. Anyway, when you fill the tranny with new fluid, do you have the car sitting perfectly level on jackstands? Or do you just have the front of the car propped on jack stands? Because that can affect how much fluid it takes to start coming out of the fill plug when you fill it up. Thanks in advance for any answers.
ScionSean is offline
Old 03-24-2007, 08:42 PM
  #208
Spect2K3's Avatar
It takes the 3 quarts. Whether its on a slant or sitting perfectly, as long as you get it to take all 3 quarts, you are fine. Anyway, I don't think that 3 quarts fill it to the VERY top. Just like we feed 4 quarts of oil to the motor, but you can probably fill it with 5 before it hits the very top. This is because it expands as it heats. So don't worry about it since the car will obviously be cold.
Spect2K3 is offline
Old 03-25-2007, 02:00 AM
  #209
chrischoi's Avatar
i still didnt do mine yet. ive had the oil at my house for a while now.
chrischoi is offline
Old 03-25-2007, 01:11 PM
  #210
web
web's Avatar
I've swapped from MT90 to Amsoil 75W/90 GL4 gear oil. A good bit smoother than redline.
Here's my review on it:
http://www.clubsciontc.com/forum_thr...--review-.html
web is offline
Old 04-07-2007, 02:24 AM
  #211
kuo34's Avatar
Well I did the swap today after a particularly long day at work. Here are a few things learned -
1) The transmission drain bolt is in a very tight spot. I was able to get to it with a 15/16" wrench. The sockets I had would fit but I couldn't get the ratchet handle into that spot.
2) Transmission fluid is very thick and slick (and messy).
3) Bolts holding in fluid have gaskets. I'd completed the swap with no problem whatsoever and was ready to pull my tC off the jack stands. I pulled the drain pan out and there's a gasket sitting there. A quick look at the drain and fill bolts informed me that the drain bolt was missing a gasket (and was starting to drip fluid), so I got my drain pan, gasket, and wrench ready, unscrewed the bolt and with MT90 flowing all over my hands replaced the gasket and the bolt. Then went on to complete the process a second time hoping I'd lost less fluid during the gasket replacement than I had remaining in my final MT90 bottle. Luckily I had enough to fill the transmission to the point of fluid coming back out of the fill hole.
4) Feeling like an idiot for the above experience quickly went away as I took my first test drive around the neighborhood.
It was a relatively easy swap, and well worth being covered in transmission fluid!
kuo34 is offline
Old 04-10-2007, 11:32 PM
  #212
purpled_out_tC's Avatar
I'm doing this as soon as I find an oil changing partner to learn first hand from.
purpled_out_tC is offline
Old 04-11-2007, 01:02 AM
  #213
kuo34's Avatar
Best way is to jump right in! And have lots of paper towels!
kuo34 is offline
Old 05-17-2007, 03:43 PM
  #214
Fsu1dolfan's Avatar
Anyone else have some more input on the amsoil.....hows it been running web....i have 3 quarts at home im getting ready to swap in!!
Fsu1dolfan is offline
Old 05-17-2007, 05:42 PM
  #215
web
web's Avatar
It's been running great ......smooth shifts and positive engagement .
web is offline
Old 05-20-2007, 02:29 PM
  #216
Concept in Motion Crew
06_t_cizzle's Avatar
dude just did this yesterday and it's a hell of a lot smoother...so happy i did this thanks!!!
06_t_cizzle is offline
Old 06-07-2007, 06:20 PM
  #217
Tenax1970's Avatar
Default Tools needed
The only tool I noted that would be needed to get this done was 1 1/16 socket with a 10" extension. Do you recall what other sizes will be needed to loosen bolts, etc?
Tenax1970 is offline
Old 06-22-2007, 04:45 AM
  #218
have a 15/16 wrench handy for the drain plug down below b/c a socket that big wont fit!!!
Old 06-27-2007, 03:05 PM
  #219
kuo34's Avatar
Yep. Unless you have a nice, thin socket wrench you'll need a wrench to get to the drain bolt.
kuo34 is offline
Old 06-30-2007, 12:35 AM
  #220
Sxy06ApTc's Avatar
I just did this swap two days ago and its great!! It has gone into reverse on the 1st try every time where with the old fluid it took up to 3 trys. Some things i noticed was why remove the reverse sensor? Napa sells a gear oil pump that attaches to the bottle for $4, i did mine this route and it worked great. Also it ONLY takes 2.5 quarts..the owners manual states this and i filled mine when it was off the jack on level ground and at 2.5 it started spilling out the fill hole as it should when its full. This is a must do mod!! Def worth the time, money and effort!!
Sxy06ApTc is offline
Quick Reply: Transmission Flush (Manual, Redline MT-90)
