Weapon-R 2008 Xb 4-2-1 Header and S pipe
#61
Originally Posted by GOZ01
Hey guys what's a CEL Eliminator ? im not to familar with this
CEL ELiminator does not allow the Check Engine Light to go on and wont let your car go into Limp Mode. Once you remove the Header and main Cat you attach the
CEL ELiminator to the S-pipe and take the sensor and plug it to the other side of the Eliminator and Gives the ECU a Correct Air Fuel Ratio Readings.
http://www.nolimitzind.com/cel.html
#62
hey guys i have the header and s-pipe but im having an issue with some rattle .....i installed the ebay scuba tank delete and the mid pipe and kept my factory trd exhaust ...anybody else getting a rattle coming from the front?
#63
Hmm im gonna ask one of the members of my the car club, i beleave he had the same problem. Def will ask and get back to you on that. Also im gonna be at the scion exposed in sarasota florida i know some guys there who have the same if not close set up.
#67
Re: cel eleminator
Originally Posted by tatwongkungfu
hey i just purchased the wr header and s pipe, coming in the mail pretty soon. I was wondering do any of your check lights come on after installing it? or did you have to install a cel eliminator?
#69
I installed weapon r header and 2.5 s pipe
hey guys recenlty i installed the weapon r header and s pipe with a trd exhaust axle back. when i turned on the engine and i rev it, it sounds like a weed wacker. But i coulnt put back on the o2 sensor on the very back of the s pipe could this be the reason why? im leaking out gas out of my muffler? can u guys show me pictures on how you installed the o2 sensor on the s pipe? mine wont fit.
#70
Re: I installed weapon r header and 2.5 s pipe
Why won't the O2 sensor fit? Are the threads messed up? If so, chase them with the correct size tap/die or go to a shop and have them do it for you. You should have a angled CEL eliminator pipe that installs into the O2 bung on the s-pipe and the O2 sensor goes into that. Sorry, no pics.
#71
The I couldn't get the o2 sensor screwed on because it wouldn't fit I need the elbow cel eliminator. After. I put the c eliminator will the raspy sound go away and have a nice high throat sound? Does anyome have a sound clip with there weapon r and s pipe?
#72
