Stock head unit
Old 06-25-2011, 06:44 PM
Admit1's Avatar
Default Stock head unit
Does the stock headunit have RCA's in the back for amp install?
Admit1 is offline
Old 06-26-2011, 02:48 AM
hmc2261's Avatar
im about 95% sure that it does not... I called the dealer about a year ago because I want a sub, im pretty sure that you need an adapter or new head unit
hope that helps
hmc2261 is offline
Old 06-26-2011, 05:41 AM
Big Sky Scion
VIP_CAMO's Avatar
What year deck?I do know the first gen 04/05 xb/xa does not.
VIP_CAMO is offline
Old 06-26-2011, 05:01 PM
hmc2261's Avatar
i have an '06 xa
hmc2261 is offline
Old 06-26-2011, 05:02 PM
hmc2261's Avatar
im just going by what iv been told, i havent taken out my head unit to check tho
hmc2261 is offline
Old 06-27-2011, 08:55 PM
IH8ONYU's Avatar
no, it does not
IH8ONYU is offline
Old 06-29-2011, 03:55 PM
ajayaitch's Avatar
You can get a low level converter or SubPlugs (if they're still being made, I have a set in the garage) to add RCA's to the stock HU. You'll need a separate way to control output though.
ajayaitch is offline
Old 06-29-2011, 08:55 PM
IH8ONYU's Avatar
simple line out converter with adjustable gains per channel - $5 walmart
IH8ONYU is offline
Old 07-24-2011, 03:11 AM
braddd123's Avatar
I'm doing the same thing. First time installing a system for me and I can't seem to figure out what wire I splice into for the remote wire to turn on the amp with my stock pioneer radio. Also what wire do I use to install this line out converter for the rca audio cable? Any help guess I'm really trying to get this done,
Thanks guys
braddd123 is offline
Old 07-24-2011, 04:08 AM
Big Sky Scion
VIP_CAMO's Avatar
Not sure if the kits are still being made but the nor cal scion group was selling the line out kits that were plug and play if you want to do some searching.Or get a hold Stylis over at Prec muffler and ask him he might know..
VIP_CAMO is offline
Old 07-24-2011, 09:06 AM
braddd123's Avatar
Well I already bought the pie aux-toy adapter and plugged that into the back of the radio and then ran the rca-audio jack out so I can use the satellite function of the radio to play my ipod on which works great. Now I need to wire my amp and sub which I'm clear on where to wire the main battery power cable and the ground but the two that I'm unsure about are the audio Wire which has rca connections which i guess an aftermarket head unit has and the "remote" or turn on wire that turns the amp on when the radio is turned on, which an after market head unit has a green 6 inch piece of wire in the back just for that function. S
Old 07-24-2011, 09:10 AM
braddd123's Avatar
so I'm not sure what wire to use to power on the amp and where the audio cable goes. I used this you tube video to reference I know it a tc but its the same radio so I was doing the same thing.
He says he uses a "line out converter" to attach the audio cables to.
1. I'm not sure what a line out converter is
2. what wires from the stock radio did he splice it into?
Thanks again guys I'm trying here
Old 07-27-2011, 08:44 PM
braddd123's Avatar
Ok so i'm guessing no ones on this site anymore.
Old 07-27-2011, 09:18 PM
IH8ONYU's Avatar
Any wire that gets power when the key is in acc position can be used as your remote wire. I think it's the grey one from hu harness.
Wires used to connect to line out converter = any if the wires from hu that go to your rear speakers.
IH8ONYU is offline
clickclickw00t
02-18-2015 08:57 PM
NewBox06
02-03-2015 04:02 AM
wiltonhall
01-28-2015 03:46 PM
billzor
Scion tC 2G ICE & Interior
01-17-2015 12:38 PM
ToyTuners
02-22-2004 10:34 PM
Quick Reply: Stock head unit
