Unbiased Unichip Review
Old 03-09-2010, 01:52 PM
greyhoundtc's Avatar
horray for an unbiased real hp/torque numbers for the unichip SEE LINK ABOVE. There have been dyno sheets on here where the unichip with an s/c fought the ecu. dropped hp and torque suddenly at 4000 rpm.
greyhoundtc is offline
Old 03-09-2010, 03:40 PM
Agent99's Avatar
I just wanted to add some zip to my daily driver tc with intake but now I'm rethinking the Unichip thing.
Maybe I'll just find a quiet catback.
Agent99 is offline
Old 03-09-2010, 11:46 PM
prighello's Avatar
Originally Posted by greyhoundtc
I am interested in the fuel savings... did it really help 2 miles per gallon or something?
but HP and torque wise the unichip unisucked... i know its for a jeep but it should have had more of an impact on more cylinders and more power, just my 2 cents
http://www.jeepfan.com/tech/OKDynoTest-2.php
Your postulation is meaningless; your data is from a different vehicle entirely. P!ss off.
prighello is offline
Old 03-10-2010, 03:26 PM
lol... i just found it interesting. so how do you know it works for the tc? 1-2 hp gain for $500 hmm...
Old 03-10-2010, 03:35 PM
CarbonXe's Avatar
lulz @ necro bump and lulz @ unichip.
CarbonXe is offline
Old 03-10-2010, 04:05 PM
prighello's Avatar
I know it works because I used it. Unichip wouldn't be in biz still if their product didn't work nor would turbonetics be using their system for their FI kit. Both are reputable companies, this is not a tornado or ground wire kit..lol. I've modded four cars with basic bolt ons and this was one few bolt ons where I felt a distinct difference...not huge but still noticeable; more so than the Cobb AP on my RX-8 which cost $800. To put it this way, if we were at the strip with identical tC's (with I,H,& E) one had the unichip and one didn't I'd put my money on the one that did pulling a better time.
Old 03-10-2010, 04:20 PM
CarbonXe's Avatar
AP for RX-8 has been dyno proven to gain 5-6% HP. Are you trying to say that your butt dyno says the unichip will provide more than 10HP? Lulz.
Oh, and you got ripped off if you paid $800 for an AP.
CarbonXe is offline
Old 03-10-2010, 04:59 PM
prighello's Avatar
What I'm saying is that the unichip is probably worth about 10hp which on a low output motor like the tC's would equate to a noticable difference.
$800 included a custom tune.
Old 03-10-2010, 05:07 PM
yellowxhoodie's Avatar
$80 for 1HP...
yellowxhoodie is offline
Old 03-10-2010, 05:32 PM
prighello's Avatar
$80 for 1HP...
Buying an AP is not all about the maps, but everything else the unit does. Besides, there really aren't any good power mods for the RX-8 other than FI, the Renesis is pretty maxed out in NA form. At least the AP offers a gas mileage map for the RX-8, which is nice when you usually get a whopping 17mpg in mixed driving. Anyway, way off topic.
Old 03-10-2010, 05:54 PM
CarbonXe's Avatar
Yes, the AP does a lot more than just add power (valet mode > all), but when it doesn't add a decent amount of power, it's basically useless.
Also, without dyno numbers, this thread is useless. I've heard people say they felt gains after installing a TRD exhaust or they had handling improvements after installing S-techs and strut bars.
CarbonXe is offline
Old 03-10-2010, 06:20 PM
BRUIN's Avatar
lol @ original post now its been edited
BRUIN is offline
Old 03-10-2010, 08:07 PM
TotalChaos's Avatar
Ahhhh, the good ol' Unichip discussion.....never seems to change. I say get it if you want it and if not, then no worries. I do wish someone show us a dyno with mods b/f unichip and then one with unichip...I guess one can dream. Forget about the Jeep dyno. Whatever....i say this thing works but how well, i have no idea. Still looking into getting one.
TotalChaos is offline
Old 03-10-2010, 10:33 PM
SilverTc06's Avatar
how much do dyno runs cost?
SilverTc06 is offline
Old 05-23-2010, 05:01 PM
Kanchi's Avatar
^about 300 for a tune
lol picked one up as well, had it re-mapped by unichip for N/A no plans anytime soon to get dyno'd but we'll see.
Kanchi is offline
Old 03-13-2012, 06:42 PM
tc1234's Avatar
I don't see why Unichip doesn't fund their own dyno tests and display them publicly. It only makes sense that they prove their product's worth. The sales would drastically increase if there was more observability of the product. It is a key concept of marketing. On the other hand, it is quite possible that the Unichip is only significantly effective on forced induction setups and there aren't numbers to back up naturally aspirated performance because it is not significant enough to be a selling point.
tc1234 is offline
Old 03-13-2012, 08:32 PM
tc1234's Avatar
http://www.unichip.us/system/uploads...20+%20CatB.pdf
tc1234 is offline
Old 03-18-2012, 07:58 PM
ThatGuyAtGeweke's Avatar
One thing i just thought i would mention about the unichip, if you are doing the mapping yourself or tuning there is a huge bonus to make this all 100% Easier.
Since we all know our scions have brains and retain learn values a way to start off on a fresh map is to start everything at 0's. Take the negative off the battery for 10 minutes, and re-attach. You should only have to do this one and i recommend the battery instead of ecu fuse. Then go under map settings on fuel and adjust injectors size until short fuel trim is at 0. Drive the 10 miles half ac on half ac off at 2300rpm to retain learn values again. Once that is done, you will not be needing to adjust all ranges just the top ranges and throttle positions where boost is. It is 1 millions times easier to tune this way. By changing the injector size in the map setting allows you to tune the system at 0 to your car. I have +1 to 5 in the higher rpm and throttle ranges and thats all i needed to change for my turbo setup. It will also cause your long fuel trim not to be stuck at -35 or whatever it finds as the middle point. Mine is -2 and your long fuel trim should be as close to 0 as possible so it has range for adjustment for the short fuel trim.
I highly recommend you do this as the fuel injector size accounts for dead time (how long they are off) it sees my 550's in my 2008 xb as 21% bigger. That put the short fuel trim and -1 +1.
ThatGuyAtGeweke is offline
Old 03-18-2012, 08:00 PM
thats the hard part man, I had a 8hp increase with the unichip over my stock with my intake header and exhaust. However no one and i mean no one wants to run 8+ psi on stock computer =/ so its hard to compare with and without it, definatly if someone is boosted. I know one thing for a fact they would not have been around as long as they have and have customer service that is willing to help you tune your car remotely with one of their road tuner kits. How many can say that =/
BlingSlade
10-19-2016 12:39 AM
That_Kid_Ju
09-30-2015 10:05 PM
Subaru86
09-14-2015 12:51 PM
Subaru86
09-14-2015 12:43 PM
ScionDP
09-08-2015 02:17 AM
Quick Reply: Unbiased Unichip Review
