Transmission Flush (Automatic, Eneos ATF)
Royal Purple Max ATF from http://store.summitracing.com/egnsea...nresults=false
, is that ok? it would be my guess any ATF fluid works for the car but this im guessing isnt "covered by warranty" correct?[/code]
Unique Scionikz
From the Summit Racing website:
"Royal Purple Max ATF is a synthetic, high-performance, long life, multipurpose automatic transmission fluid. It is recommended for all automatic transmissions requiring Ford Mercon or GM Dexron III transmission fluids. "
Doesn't say anything about Toyota Type-IV
I was thinking about ordering it to but I didnt have enough time to do it bc I was pushing to have it done so I just went and got ATF for the dealer. But himynameischris if you could let me know how the max ATF works that would be great!! Thinking about getting it but would like to see what you think of it when you get it in your tranny!
Thanks,
Chris
Thanks,
Chris
We got all ENEOS oils in stock- FREE Shipping
http://www.carcandymotorsports.com/i.../cPath/404_406
Greg
Greg
wow summit is fast, (and close) i just got the tranny fluid TODAY, ordered yesterday recieved today A+, ill install it tonight and will be cruiseing around ill give some feedback!.
*edit* fluid was installed and the car ran beautiful, it shifts much smoother and harder, my friend was even complimenting it after it was done.....
I wouldn't use anything but type IV
I wouldn't use anything but type IV. It can void your warranty. Also the dealer charges X amount of $ because we at least my dealer flushes all the old fluid out. A drain and fill will not take out all the old fluid. There will still be a good amount of dirty fluid in the tranny. Just like a drain and fill on a radiator will not take out all the dirty fluid in the cooling system.
yeah but go ahead and flush a valve body, not the best idea for them. No matter if a "dealer" said it was good. Also power flushing an aluminum radiator, not a good idea if you don't want to have something rupture. Aluminum = Thin = No flushing, just drain.
I would just drain and refill like Toyota recommends (even in the service manual they only recommend draining). At how often people are draining it, like every 15k to 20k miles you have nothing to worry about. I would worry about flushing the entire trans with a pressure machine! ouch!
Sorry bro,
Your wrong. At least on any of the machines I have ever used. The coolant flush machine won't even run if the pressure is to high. The trans flush machine puts lets pressure on the trans then it gets during normal use.
hey guys for info toyota's tranny fluid is Dex-III if u look at the back of the bottle, its honda that is really strict on their tranny fluid anyways anyone have a writeup on auto tranny's tranny filter change like how does it look when i pull it off?
Hi
for any miles - have to be ATF oil changed?
for any miles - have to be motor oil changed?
maybe some one have photos - how to chnage oil filter?
thanks in advance
www.scion.pl
thanks in advance
www.scion.pl
