Hvac issue
Old 04-01-2014, 11:35 PM
DaTRican's Avatar
Default Hvac issue
So sometime in the last week my radio blew a fuse...whoever owned the car before me left the wires exposed when they did the install. Any who but when that fuse blew (I replaced it of course) my hvac lights don't work. I have no clue on what to do. Any input would be much appreciated!
DaTRican is offline
Old 04-03-2014, 03:57 PM
DaTRican's Avatar
No one?
DaTRican is offline
Old 04-03-2014, 04:32 PM
criminaltc's Avatar
Yeah sorry man. Saw this two days ago and had nothing for you. I still don't. I'd have to see it I guess to start poking around.
criminaltc is offline
Old 04-03-2014, 04:37 PM
electrongeek's Avatar
I guess if I was in your situation I would probably start by unplugging the hvac and plugging it back in to see if that does anything. Other than that I'm at a lost as well.
Does your clock work? Also does the hvac operate on a fuse of its own? Sorry I'm not much of help either.
electrongeek is offline
Old 04-03-2014, 04:42 PM
DaTRican's Avatar
I'm uploading a small video to YouTube to help get you guys a better idea
DaTRican is offline
Old 04-03-2014, 04:59 PM
DaTRican's Avatar
Hvac issue:
DaTRican is offline
Old 04-04-2014, 06:14 AM
DaTRican's Avatar
Bump
DaTRican is offline
Old 04-04-2014, 02:22 PM
criminaltc's Avatar
Hahah!! Oh!! Now I get it. Yeah that video was much needed. I had no idea what you were talking about. Looks like someone tapped into those wires to maybe do an aftermarket something, and they grabbed those wires so they could control when the item would be on or off based on the steering column light toggle, but they clearly did something backwards. Also, you mention that the previous owner "did the install." That's all you said. So what does that mean? What install? And has your lights always done that, or just after the fuse blew? Because if that were the case, then it's still fuse related and you need to check all of them. There will be multiple that play into effect for your steering column light toggle. The radio fuse will have absolutely nothing to do with the fuse that is related to those lights on your hvac.
Old 04-04-2014, 02:41 PM
DaTRican's Avatar
I did the led mod for the hvac lights it use to look like this
The part that the previous owner did was the radio install...and basically every wire was exposed. No black tape no nothing.
DaTRican is offline
Old 04-04-2014, 02:48 PM
criminaltc's Avatar
Haha. So you putzed with the lights and now they don't work? This is on you man.
Old 04-04-2014, 02:50 PM
DaTRican's Avatar
The FUSE blew for the radio in the car then it stopped working
DaTRican is offline
Old 04-04-2014, 02:51 PM
criminaltc's Avatar
Right. I get that. So something else was effected as well, either with you wire job or another fuse where those lights are wired to.
Old 04-07-2014, 03:30 AM
Spanky37's Avatar
Unfortunately it isn't much help, but for what its worth, since I installed my system, my left HID headlight only turns on if I turn on->off->on my lights. The initial install isn't what did it, and it wasn't affected when screwing around with any wires to the stereo etc, what did it was when I upgraded a 20 fuse to a 40 from the battery to the 0 gauge positive that goes to the amp in my trunk. To test it, I downgraded back to the 20 (didn't run my sub on it though), and the headlights worked fine again.
If you changed any fuses or wires from your battery to an amp, that may have caused it. Don't ask me how that even makes sense cause I have no idea.
Edit: For clarity, when I say fuse, I don't mean a fuse in either of the fuse boxes.
Spanky37 is offline
nazblue5807
04-11-2015 12:20 AM
zap-o-matic
04-02-2015 07:35 PM
missing_image
02-07-2015 07:18 PM
Austin292
Scion tC 1G ICE & Interior
01-15-2015 03:52 AM
cid_mcdp
Maintenance & Car Care
01-05-2015 02:45 PM
Quick Reply: Hvac issue
