xB Camber 101
Old 02-15-2009, 12:34 AM
Tamago's Avatar
i'd like to add that i've seen as much as -4deg of camber in the front, utilizing just camber bolts, on a 2.25" drop.
Tamago is offline
Old 04-24-2009, 12:27 AM
ratcityrain's Avatar
thank you for the write up.. i'm getting a set of the otg camber shims tomorrow and just trying to learn more about cambering.
thanks - very good write up
ratcityrain is offline
Old 02-12-2010, 06:00 AM
eight08customs's Avatar
www.forjworks.com is realesing some new Camber shims!!!!!
http://ecocarcustoms.com/Topic122-62-1.aspx?Update=1
eight08customs is offline
Old 02-22-2010, 03:37 PM
bbszero's Avatar
I have -3 camber, and spacers too.
https://www.scionlife.com/forums/sho...d.php?t=168127
bbszero is offline
Old 10-15-2010, 12:16 PM
mwolfe25's Avatar
this is great info thanks for putting it on here.
mwolfe25 is offline
Old 05-03-2013, 10:42 PM
Tffnyv's Avatar
I'm really just trying to figure out why my rear camber would be so out of wack. I've not modified anything, it's all stock.
Left camber: -1.5
left toe .22
Right Camber -1.5
right toe .20
Cross Camber .0
total Toe .43
Thrust angle .01 I guess it's the toe they recommend fixing, and say with shims they can resolve the issue.
I truly know nothing about this stuff, I'm just trying to prevent getting taken advantage of buy some unsavory mechanic.
Tffnyv is offline
Old 07-20-2013, 06:35 PM
markio's Avatar
this is the BEST THREAD EVER
markio is offline
Old 10-01-2013, 10:59 PM
White_Wolfe's Avatar
I am out about -1.4 on the passenger side front and rear. I have a full contact shim for the back. I also have a camber bolt for the front, but I thought they came in pairs when I ordered.
Is changing the upper bolt enough, or should I go ahead and do both bolts?
White_Wolfe is offline
Old 07-11-2015, 11:53 PM
x2x3's Avatar
Wow, bump it up
x2x3 is offline
Darrenohooligan
09-26-2015 07:21 AM
scionhawaii
09-01-2015 08:14 PM
domincnTC
08-04-2015 01:47 PM
Subaru86
07-31-2015 04:33 AM
Subaru86
07-31-2015 04:00 AM
Quick Reply: xB Camber 101
