205/65/15 too big?
Old 11-14-2013, 05:35 PM
bentheswift's Avatar
Default 205/65/15 too big?
Some local "used for one season" studless snow tires on craigslist for a really good price. However they are 205/65/15s.
The width does not worry me, but they are a full inch larger diameter. Think that is too big (i.e. potential rubbing)?
I did some forum searching and the typical 17 and 18 inch sizes that people here tend to stick with are not usually that larger. Speedo difference would only be 4 percent.
Any input is helpful.
bentheswift is offline
Old 11-14-2013, 07:09 PM
DaWiz711's Avatar
Here's 205/60 on the front; you'll have rubbing at full lock unless you're willing to do a bit of hammering, but it shouldn't be that bad
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
Attached Thumbnails 205/65/15 too big?-uploadfromtaptalk1384459746236.jpg
DaWiz711 is offline
Old 12-12-2013, 07:15 AM
Nerdcore314's Avatar
Thats the exact size tires I'm running on my 2005 xa. They came with some rims I wanted. They did make me go down 2mpg if you care. I track every fill up I've ever done on the car so it's not a number pulled outta my ___ like most people do
Nerdcore314 is offline
Old 12-17-2013, 06:27 PM
TheShortBus's Avatar
Bentheswift:
I've run Falken ZEIX 512s on my 05 xB spring through fall in 205/55 x15" on four aftermarket alloys with absolutely no issues. In winter I have another set of four alloys with Hankook snow tires (iCE PiKE?) in 195/65 x15—again, with no problems. 168,00 miles and almost nine years!
TheShortBus is offline
Old 10-06-2015, 03:40 PM
xxRayTardedxx's Avatar
Default 05 Scion xB tires
I have 205/65/15 the rear no issues at all. The front will rub at full turn and you may have to trim a little off the plastic. About a inch in the arch where it rubs. When they get a little wear the rub goes away.
xxRayTardedxx is offline
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
yupinmytC
21
11-08-2019 09:34 AM
neneago
10-27-2015 04:47 PM
Blunderbuss
10-08-2015 04:56 PM
Sgtfluffy16
09-30-2015 01:42 PM
Quick Reply: 205/65/15 too big?
