Transmission/Clutch/Flywheel issue
Old 04-29-2012, 04:13 AM
N0AuTHoRiTy's Avatar
Default Transmission/Clutch/Flywheel issue
Hey everybody,
I was looking to see if anybody could give me some input on this.
I had recently done an e351/Camry transmission swap with a brand new Exedy Stage 1 clutch and Competition 12lb lightweight steel flywheel, install process went smoothly without any issues. After everything is said and done, this is the issue I have.
1) Car will NOT shift into gear when wheels are on the floor.
2) Car will shift into gear only when it is lifted and there is no load on the wheels. I tried shifting through all 5 gears with no problem, including reverse.
Things I have tried
1) Adjusting the clutch pedal.
2) Bleeding the slave cylinder.
Parts that have been changed within the past year or so.
1) Slave cylinder (10k miles)
2) Clutch master cylinder (10k miles)
Any input from fellow forum members would be very much appreciated. Thanks.
N0AuTHoRiTy is offline
Old 04-29-2012, 11:23 PM
Bump
Old 04-29-2012, 11:24 PM
Roller_Toaster's Avatar
Is the slave cylinder engaging when you push in the clutch pedal?
Roller_Toaster is offline
Old 04-30-2012, 12:24 AM
From what I can see, the slave cylinder is making contact with the clutch fork. The thing is, I have no idea how far the pushrod is supposed to extend out. I would say it is extending at least 1/2 inch out, little more or less.
Old 04-30-2012, 01:09 AM
Have you tried adjusting the clutch pedal? (Turning the two nuts at the back of the pedal itself to adjust the throw of the slave cylinder.)
Edit: just saw that you tried adjusting it.
Old 04-30-2012, 04:20 AM
Yup, tried that. I was wondering if anybody was able to take a video for me of how much the slave cylinder pushrod is supposed to travel? If you can kindly send it to my email at n0authority@hotmail.com, that would be greatly appreciated. Thanks
Old 05-01-2012, 12:06 AM
Bump
djcezile
04-23-2015 06:46 PM
nazblue5807
04-11-2015 12:20 AM
wg93081
04-09-2015 07:47 AM
zap-o-matic
04-02-2015 07:35 PM
cid_mcdp
Maintenance & Car Care
01-05-2015 02:45 PM
Quick Reply: Transmission/Clutch/Flywheel issue
