DIY: Auto Transmission Drain and Fill (1st Gen xB)
Old 12-01-2010, 05:24 AM
teabox's Avatar
I wouldn't know. Could possibly damage the tranny.
teabox is offline
Old 12-01-2010, 12:09 PM
Bobb_Todd's Avatar
Noted that in the first post it said to shut the car off, then check the auto trans level.
Every automatic I have owned requires you to check the fluid level while the car is running ?
Bobb_Todd is offline
Old 01-18-2011, 05:01 AM
padillaXA's Avatar
the only cars i know of that you have to check while off are hondas. everything else has got to be on.
padillaXA is offline
Old 02-14-2011, 11:24 PM
ebrann's Avatar
So which is it engine off or engine on? I read this entire chain hoping to find the answer to that question.
ebrann is offline
Old 02-17-2011, 01:20 AM
Keith's Avatar
on the auto tranny, I was told it has to be running...
Keith is offline
Old 09-11-2011, 10:47 PM
ToddMS's Avatar
I think the last time I looked at the dipstick it had a cool engine and a hot engine level. Also know that the BG flush, used at my dealership, uses chemicals to clean the sediment out of the system. I would not do the full flush after 100k if it has never been done before as I have heard horror stories of the chemicals cleaning grooves out of the trans causing huge problems afterwards.
As for Fluid type: Alldata says
DRAIN AND REFILL: 3.1 qt. (2.9 L, 2.6 Imp. qt.)
FLUID TYPE: Genuine ATF Type T-IV
Just looked up the other gen1 years and they also say 3.1 d&r however, the 04 says that a dry fill is 7.2 qts.
ToddMS is offline
Old 03-06-2013, 10:36 PM
johnetrue's Avatar
I have a 06 xa had since new never had tran or coolant serviced 106,000 what should I do
johnetrue is offline
Old 05-08-2013, 02:12 AM
teabox's Avatar
For transmission, if you feel any "shock," "jump," or "shutter" when the trans is going to different gears, then its a good time to drain and fill with the 3 quarts of fluid. The point of this thread is ONLY for preventative maintance to prolong the life of the transmission.
teabox is offline
evolving_machine
10-21-2023 01:16 PM
GoodVibes
21
05-22-2020 04:27 PM
rjjablo
16
02-19-2020 12:42 PM
12thhawksfan
07-14-2015 06:18 AM
JM Auto Racing
12-19-2014 06:36 PM
Quick Reply: DIY: Auto Transmission Drain and Fill (1st Gen xB)
