Spark Plug Change
Old 01-10-2007, 03:26 AM
  #41
Hoshizaki's Avatar
Thanks for the write up. Nice photos.
Hoshizaki is offline
Old 01-23-2007, 09:44 PM
  #42
livingston2's Avatar
Default Thanks
Nice Job on the DIY!
Does anyone ever use Bosch plugs?
I just installed them so I hope they are ok
livingston2 is offline
Old 03-06-2007, 11:00 PM
  #43
mike51392's Avatar
^^^^^^^^yeah really im a bosh type of guy ^^^^^^^^^
funny i was just starting to complain about mpg's and accel during idle i just relized i have 27000 miles and 85% of the miles are city (traffic 405) miles - i know what im doing this saturday
mike51392 is offline
Old 04-09-2007, 03:21 AM
  #44
Dwatts5250's Avatar
So I guess, with my car being at 51000 miles I should probably change the spark plugs...? And maybe the PCV valve?
I change my oil every 5-7 thousand miles, I use FULL synthetic.
Dwatts5250 is offline
Old 05-05-2007, 01:35 AM
  #45
SuperMario6582's Avatar
thanks to this super easy to follow DIY i was able to change out my spark plugs in about 15 minutes.
SuperMario6582 is offline
Old 05-05-2007, 05:01 PM
  #46
vintage42's Avatar
Originally Posted by Tay831
... I also changed the pcv valve both were in terrible condition ...
How can you tell if a PCV valve is in bad condition?
vintage42 is offline
Old 05-12-2007, 10:21 PM
  #47
Max
Max's Avatar
Changed mine at 28,000 earlier today.
Max is offline
Old 05-13-2007, 06:41 PM
  #48
vintage42's Avatar
Originally Posted by Max
Changed mine at 28,000 earlier today....
The old plug still looks perfect. No erosion or rounding of the electrodes, no deposits except a little proper fawn color.
Old 05-13-2007, 06:43 PM
  #49
you guys dont even want to know what my old plugs looked like! haha!
Old 05-13-2007, 10:51 PM
  #50
jct
jct's Avatar
i got 800 more miles till i change my plugs, btw max your old plugs looks normal
jct is offline
Old 05-14-2007, 01:05 AM
  #51
Max
Max's Avatar
Yeah, they look good, but getting the old ones out was quite the ordeal with the STB, so I wasn't going to put them back in, only to take back out in another 5k or so. Maybe it's my imagination, but my butt dyno felt a huge power increase.
Max is offline
Old 05-14-2007, 05:49 PM
  #52
vintage42's Avatar
Once they are out, no point putting them back, but it's interesting to see how good they look at around the 30K miles where they are scheduled to be changed.
A true power increase will also be reflected in better mpg, if you continue to drive in the same way that you did before without using the "increased" power.
It's not the same power increase you get from washing the car or changing the oil, is it?
Old 05-14-2007, 11:06 PM
  #53
Max
Max's Avatar
Yeah I know. It's tough, but I am trying to be good.
lol, no.
Max is offline
Old 06-29-2007, 04:58 PM
  #54
randyb359's Avatar
Default Re: Spark Plug Change
10. Once the plug is screwed in you can use the torque wrench to tighten it to 13 ft lbs
-or-
after it's hand-tight tighten it 1/2 a turn more.
I bought bosch platinum+4 and it sais 21 ft lbs. Do different makes of spark plugs get different torque? Does using anti seize compound affect the recommended torque? I was confused and needed to use the car so installed mine doing 1/2 turn witch was 18 lb. Did I hurt anything? should I adjust it and if so to what?
randyb359 is offline
Old 06-30-2007, 02:01 PM
  #55
vintage42's Avatar
Originally Posted by randyb359
"10. Once the plug is screwed in you can use the torque wrench to tighten it to 13 ft lbs -or- after it's hand-tight tighten it 1/2 a turn more."
That sounds OK according to http://www.nology.com/torque.html.
I always use anti-seize to avoid problems. My brother was once unable to get a dry plug out of the engine, afraid he was about to ruin the threads, had to leave it halfway out and run like that until he took the car to a shop.[/i]
Old 01-21-2008, 04:16 PM
  #56
adamisbomb's Avatar
mine has 55k on it and the idle is rough. gonna go buy some plugs at autozone today and put them in, thanks for the write up
adamisbomb is offline
Old 01-22-2008, 01:38 PM
  #57
HeathenBrewing's Avatar
You really cant tell for sure. even if it rattles, it may not be working correctly. For $4.00, just replace it.
HeathenBrewing is offline
Old 01-22-2008, 03:54 PM
  #58
adamisbomb's Avatar
my plugs looked just like the one above. it was pretty ugly. hopefully idle is smoothed out with the new plugs....i got ngk plugs that were 3 bucks a plug.
Old 02-04-2008, 01:29 AM
  #59
AKgoalie7's Avatar
Just changed my xB RS 1.0's plugs to NGK Iridium iX-11 with the .044 gap...
Everything went smoothly, works fine. Was a little scared when I started breaking the old plugs free. Don't think the dealer used anti-seize on the first replacement.
Can't believe I didn't do this sooner.
Great write up!
AKgoalie7 is offline
Old 03-27-2008, 12:33 AM
  #60
bigskyscion's Avatar
Super helpful DIY. Thanks!
bigskyscion is offline
Quick Reply: Spark Plug Change
