Sway Bars Discussion
Old 12-01-2008, 07:06 PM
  #101
swartzautoman's Avatar
great thread, ive learned a little.
with the whiteline you need to look for a sway bar from the Echo.
i did some research and found another compainy ST Suspension Techniques.
its a 11/16 (about 18mm) rear sway bar for about $176.
you can get it from Jeggs but its a 3 to 4 week ship time.
also the hochkens is 15/16 and its hollow (for the rear)
id like to get a ST "and" a Whiteline.
ive seen others that run 2 swaybars in the rear and they say it handles nice.
swartzautoman is offline
Old 01-19-2009, 01:52 PM
  #102
JDM101's Avatar
Nice thread. Very informative.
Now here is my question. I have a 2001 Toyota bB (Japan unit).
Can I use the same Progress Rear Sway on my Box?
____
JDM101 is offline
Old 03-16-2009, 04:01 PM
  #103
stonecoldnimrod's Avatar
So I bought a TRD Sway Bar on eBay for $100 and Wow, the difference is astounding. For one, it took me longer to jack up the ___ of the car and sit it on stands that to actually install the bar.
And the feel is great, especially with my DF210's. Whomever hasn't done it yet (it took me over 2 years to get this done) needs to do this mod asap!!!
___
stonecoldnimrod is offline
Old 05-06-2009, 11:19 PM
  #104
spr0k3t's Avatar
Just installed the TRD on my box. I found if I removed the rear wheels, install was a snap. I spent more time prepping/jacking than I did installing and torqing. The handling of the box is 100% better. Corner handling is much smoother and the roll is almost completely gone. I have no other suspension mods on my car.
After reading some of the information posted here, I'm thinking it may be best for a front strut brace on my car.
spr0k3t is offline
Old 05-07-2009, 12:53 PM
  #105
evosky's Avatar
lowering springs will do much more than the front strut brace in terms of eliminating roll and increasing tightness.
evosky is offline
Old 05-07-2009, 01:17 PM
  #106
spr0k3t's Avatar
Thanks for the recommendation evosky. The df210s are the next suspension mod anyway.
spr0k3t is offline
Old 09-28-2009, 12:31 PM
  #107
txdo_msk's Avatar
Default Adjustable Sway bar solution...
Sorry if this has been touched on already.
I was driving back from Church yesterday, and an idea hit me.
I have the Hotchkis Rear and Front Sway Bar set on an 05 xA, and while it works great, I think I can make it (the front one) better. Ever notice how the end link connector is horizontal to the ground? And only has one hole? Kinda makes it hard to adjust.
Over the next month or so, I am going to find someone to weld up a sleeve for the ends that has a vertical steel plate with more holes, and also have a connector made to fit in the cup (might need to drill it out for a beefier bolt) on the lower A-Arm, with a matching vertical plate.
Voila! It's now adjustable!
_____
txdo_msk is offline
Old 12-30-2009, 03:45 AM
  #108
swdonogh's Avatar
Question My Dream
I own a 2006 Scion tC with Spoiler, Ceramic brakes, Smoke front and rear lights with LED, Fog and driving light, Leather and heated seats, and new rain tires. Now I want it to corner better. I am not a member of a club because I cannot find one in the Seattle area so information is hard to come by. I was looking at a set of sway bars from AutoAnything. I don't want too big of a front bar because I don't want too much oversteer. I want it to corner like my 2006 Boxer, completely predictable or like my 1972 Corvette Z-30, which a ZL-1 with a small block. It is also completely predictable with power on. I don't think you can realistically spin a Boxer with the electronic suspension on. What does anyone think about sway bars on a Scion tC? I don't want so much lean and sway. Do I have to lower it? Do I have to change struts? I hope the sway bars will reduce lean and ad more controlled drift. Open for Comments, Stan
_____
swdonogh is offline
Old 12-30-2009, 04:54 AM
  #109
3min3m2's Avatar
Wow hold on man...slow down here.
Take some more time to look around the forum for these questions. I know there are even answers on here from 06, where I asked the questions.
for a brief answer, Sways are Awesome. I had the TRD Rear, which is pretty much enough. Car is ____ near neutral in the corners, even pushing it HARD. I would definetly call it predictable.
I currently have the Hotckis sways, set soft front, medium rear. Currently I have a little much oversteer for my taste when pushing. but nothing beats being able to adjust sways to your taste, I just finished setting front to Hard and left rear on middle.
Granted these results are for the Auto tC, the manual is lighter on the front a tad and generally has slightly more oversteer.
Good luck though...
3min3m2 is offline
Old 12-30-2009, 11:35 AM
  #110
txdo_msk's Avatar
I autocross my 2005 xA, so I've learned a bit about suspension, pretty much all of which can be found in one form or another on this site.
That being said, the Stock sway bar is "enough". However, you can't beat tunability. Hotchkis all around for your tC will greatly improve the tunability of the tC's setup.
Also, a trick I learned from autocrossing is to air your rear tires more, like 10 lbs more, if you want some oversteer. The stiffer the rear, the more it will slide out.
You can also look into stiffer springs. The TRD springs, which I have on my TRD struts are about 10% stiffer than stock. You can get much stiffer springs elsewhere, which will also tune you suspension, depending on what you want.
I would recommend campaigning your car at a few autocross events and ask some of the more experienced people watch and see what's going on with your car. Another autocross trick is to fasten zipties to the tops of the shock
cylinders to see what your travel is, this can tell you a lot about how everything's working.
_____
txdo_msk is offline
Old 09-11-2010, 08:50 AM
  #111
itscurtsk's Avatar
I'm looking forward to the TRD or Progress rear sway bar, and just leaving the front stock and adding a strut bar.
Any good deals out there?
____
itscurtsk is offline
Old 09-28-2010, 06:26 AM
  #112
teabox's Avatar
Handles very nicely. I have the BTR76 for the xB.
teabox is offline
Old 02-07-2012, 11:20 PM
  #113
Kevlar's Avatar
What if you have a Yakima rack with a basket case on it. That's allot of weight on top of the Box.
Will a Hotchkis front sway bar work better for that set up?
Autocrossing you don't do with big racks and passengers. Daily driving you do.
So, my question is: For daily driving with some extra weight added on the Box, would a Hotchkis sway bar work for your advantage when making a hard turn?
This is a great thread. Thought I would keep it alive.
In my xA I thought putting -3 camber shims made the car over steer.
-3 camber made it over steer allot. A lot of fun that is.
I don't know about the xB. haven't tried it yet.
_____
Kevlar is offline
Old 03-04-2012, 01:44 AM
  #114
Hites's Avatar
How do you do that?
Hites is offline
Old 05-31-2012, 07:01 PM
  #115
pdool09's Avatar
Originally Posted by nest
It's my understanding that front anti-sway bars actaully contribute to understeer. They force you to back off on the speed in a turn before you are actually out of lateral grip. It makes the car "safer" for less experienced drivers, which is why most cars come with them, but they don't actually improve handling beyond a certain point.
I learned a lot of what I know from a VW/Audi/Porsche suspension expert up in MA (Dick Shine) and he doesn't include front sway bars in any of the custom suspension systems he built. He usually recommends leaving the stock bar, definitely NOT a thicker front bar. He suggests removing the front bar altogther in some cases for experienced drivers.
Even though he was mainly a VW guy, its relevant here:
The xB is a front engine, front wheel drive compact with Mac Struts in the front and a torsion beam rear suspension.... and so are every single VW Jetta, Golf and New Beetle on the road. ;)
Here's how he explains it:
"Volkswagens have between 65-70% of their weight over their front wheels which causes understeer. Larger front sway bars cause more understeer and unload the inside front wheel during hard cornering resulting in wheelspin. This is a major handicap, especially when autocrossing. Shine Racing suspensions are designed to minimize understeer and increase grip."
I think that the xB has a better weight distribution ratio than that, but, like any FWD, front engine car, the balance of the weight is over the front wheels with the engine, transaxle etc..
Agreed - well stated
pdool09 is offline
Old 03-27-2013, 08:55 AM
  #116
Ben180's Avatar
very ez install
Ben180 is offline
Old 03-27-2013, 06:27 PM
  #117
Ben180's Avatar
My instincts tell me to get the stiffest rear bar I can find and leave the front alone. Has anyone gone that route?
TRD REAR ALL U NEED..
Ben180 is offline
Old 03-17-2014, 03:57 PM
  #118
scionxb1stgen's Avatar
Default Safety issue with sway bars?
For the daily xB driver is it safer (less chance of rollover and better steering ) to remove the sway bar on all 1st Generations?
____
scionxb1stgen is offline
Old 07-12-2020, 06:41 PM
  #119
Zieman's Avatar
Default What Brand is Best Replacement on 2005 xB Swap bar links?
I bought Energy Suspension sway bar kit.. It was ____ totally way over size and centers bolt was so long it would only go in upside down. and it still hit the Drive axle.
Is the factor replacement the way to go... only one that looks correct.
Any suggestions... Thx Rz
_____
Zieman is offline
Old 07-18-2020, 12:48 PM
  #120
Stames's Avatar
Zieman,
I ran into this issue as well with the Energy Suspension end links. It's been a few years, so I can't recall how I modified these to work. I think I may have cut the bolt, but I can't be sure.
Here's a picture that should help. The suspension is fully extended and clears just barely. There is much more clearance while the suspension is compressed. Also, this is a Celica GT-S axle, which is slightly larger than the stock XA.
Stames is offline
Quick Reply: Sway Bars Discussion
