Regional - Pacific Mid CA, NV
Newbie Chick.. Place to install mods?
Old May 3, 2007 | 08:59 AM
babiblujay's Avatar
Default Newbie Chick.. Place to install mods?
I goto UC Davis, so I need somewhere near there. I'm close to sac. Any suggestions for a good shop that'll install for cheap?
Old May 3, 2007 | 11:59 AM
XBbarkeeper's Avatar
I don't know how cheap he is but Hotbox05 (aka Darren) with NVS is usually looking for some side work.... Try
PMing him...
Old May 3, 2007 | 06:08 PM
etli's Avatar
You might try asking over on the NVS board- "North Valley Scions". Those guys are mostly based around Sacramento but they're close to you than we are if you're in Davis.
Old May 3, 2007 | 07:51 PM
babiblujay's Avatar
I don't see the board. where is it?"
Old May 3, 2007 | 08:01 PM
www.northvalleyscion.com
Here you are. :D
Old May 3, 2007 | 08:11 PM
babiblujay's Avatar
i registered and everything, but there are 0 posts and everything is locked....
Old May 3, 2007 | 08:50 PM
SquallLHeart's Avatar
most parts of it are "private" and you will need to contact someone to get full access... there should be something on there that tells you about it.
Old May 3, 2007 | 10:33 PM
babiblujay's Avatar
cool thx.
Old May 3, 2007 | 10:45 PM
NVSHSKR's Avatar
You won't be able to access the site until you have attended a few meets. What work are you looking at having done I am sure Darren can help you out you can PM me or him and we can work something out.
Old May 3, 2007 | 11:38 PM
babiblujay's Avatar
I'm planning on getting rims and tires with trd spring, struts and rear sway bar. all installed at the same time for convenience
Old May 4, 2007 | 12:41 AM
etli's Avatar
Buying parts online I hope? Good luck, it shouldn't cost too much to install all that for labor since you're doing it all at once.
Old May 4, 2007 | 02:38 AM
babiblujay's Avatar
yea. getting it at wheelfire.com. comes mounted and balanced and free shipping. about 1250 for tires and rims, 750 for trd springs, struts and rear sway
Old May 4, 2007 | 05:03 AM
sciontc0115's Avatar
try www.tirerack.com and trdsparks.com maybe find everything alittle cheaper
Old May 4, 2007 | 06:09 AM
payattn2me's Avatar
hey! i go to UCD too. maybe i'll see u round
Old May 4, 2007 | 07:48 AM
babiblujay's Avatar
ooh cool. where do you get ur stuff done?
Old May 5, 2007 | 01:22 AM
tcninja's Avatar
Coolio, I'm about to graduate from Davis, Darren (hotbox05) does good work.. I recommend him.
Old May 5, 2007 | 04:51 AM
debris's Avatar
yeah hit up darren....and hit up jessr om the nvs forum to get into our private section
Old May 5, 2007 | 04:59 AM
babiblujay's Avatar
I pmed jessr, but he said that I couldn't join unless i was a member.
Old May 5, 2007 | 05:04 AM
debris's Avatar
hmmmm......understandable.....weve had alot of spam on there,
come out to a few meets when your up in sac then....
did you get ahold of darren?
Old May 5, 2007 | 05:39 AM
bB_Local_Boy's Avatar
Can I hang out with you guys in Sac if I promise not to cause any problems?
