I lifted the carpet behind the back seats. There are red and black wires with electical tape on the ends. Also, a pair of RCA connections. Is this for an amp or subwoofer?
Did you buy the car used? I can't remember if the RS1's came with the factory sub or not. Even if they did, that means that yours isn't there, or somebody had an audio system in it.
'05 SSM tC - Totalled 9/28/07
'06 Audi A4 Quattro 2.0T 6-speed sedan - STaSIS coilovers, EVOMS Intake, APR Snub (motor) Mount, H&R 5mm/8mm spacers, blackout grill, smoked sidemarkers, GT yellow fog lights, 20% tint, RS4 Rear Sway Bar, VEI Systems Boost Gauge with Podi steering column mount, APR 93Oct. Reflash, OEM "G" DV, EuroJet PCV valve fix.
I'm always lurkin' son, ready to strike.
No, its not factory. Scion is not going to put electrical tape on the ends of wires and leave them under the seat. It was from an installed amp. You might be able to use it if you want to put an amp in, but I'd redo it all myself to be on the safe side...
07 BSP tC
Gold Drag DR9 wheels
Tein S-techs
Megan axle-back Driftspec
TWM Stage2 short shifter w/ TWM weighted ****
Pioneer Avic-D3, Kenwood amp, Exile Sub, JL TR650-CSi front components, Element antenna, Sirius
20% tint all around with AVS in-channel ventshades
The person who tore out the sub to sell on ebay HOPEFULLY would put electrical tape on the power wires to keep them from shorting, and his battery exploding.
I'm pretty sure it's the factory sub wiring because last time I checked, large gauge power wire was wrapped in PVC, not black and white shrink (which is what i'm inferring from his post). I'm not sure if it used RCA inputs though. I may be wrong.
Is the stock head unit still in the car?
someone had a system in there and took it out...Factory NEVER uses RCA's to transfer sound, they like hi-level inputs rather than low level...and if you have a factory stereo u might wanna check behing it and see if someone has left you a line converter back there.....since there are RCA's in the back.
2005 SW tC : H&R racing springs, hotchiks rear sway bar, Sparco Racing 18" wheels, nitto extreme 555 tires, sparco shift ****, short shifter, FIG grill, debadged tC, green Randode cold cathode kit, RF P3001 Amp, Kenwood Tornado series sub
