View Poll Results: What would be the best 2 gauges to monitor a supercharger with?
Boost & Oil pressure
100.00%
Boost & Voltage
0%
Voters: 7. You may not vote on this poll
Gauges for Supercharger
Old May 14, 2007 | 05:28 AM
skullsandcandy's Avatar
Default Gauges for Supercharger
Alright gang I need some input on gauges for monitoring my supercharger. Right now I am only planning on doing a 2 pod a pillar mount and I can't decide which 2 gauges to get.
Neothin's Avatar
boost + wideband would be my 2 choices
Old May 14, 2007 | 05:32 AM
Why wideband?
Old May 14, 2007 | 05:35 AM
Neothin's Avatar
because it's quite possibly the most important gauge when you're going FI? tells you up to the second if you're running dangerously lean which skyrockets EGT's and blows ish up
Old May 14, 2007 | 05:41 AM
Thanks for your input neothin -- I will consider getting a wideband a/f as the second gauge. I just need to see if Cyberdyne makes that would match up with the boost
Old May 14, 2007 | 05:44 AM
Neothin's Avatar
no they don't
http://www.egauges.com/vdo_grou.asp?Series=Cyber_Red
you'd hav eto go with a different gauge manufacturer to get a wideband. narrowband afr gauges dont do much ^^
Old May 14, 2007 | 05:50 AM
Well it would tell me if it was extreme either way though. I really don't think the supercharger is going to give me much of any worries honestly. I think there are a few people that aren't running any gauges with theirs The only reason I like the Cyberdyne is for the boost... the supercharger boost level isn't very high but all of the gauges are -30/+30. I would much rather have a shorter range so I can clearly monitor where I am hitting. Make sense?
Old May 14, 2007 | 05:52 AM
Neothin's Avatar
0-23 according to this-
http://www.egauges.com/vdo_mult3.asp...er_Red&Units=E
wells... if you decide against eh wideband, oil pressure would be my next choice. volts won't help you monitor anything haha
Old May 14, 2007 | 05:56 AM
Well the supercharger is running off the alt pulley etc my thought would be to make sure I am not about to blow that up as well The upside of the cyberdyne boost regardless of range is that it shows a solid number and not a needle float on an overlay. It is too bad they dont make a wideband a/f
Old May 14, 2007 | 06:05 AM
Neothin's Avatar
if you're that concerned about a digital display... look at the AEM UEGO wideband and the AEM TruBoost. both have digital displays. yay!
Old May 14, 2007 | 06:07 AM
Those are nice ... and pricey haha... damn
Old May 14, 2007 | 01:53 PM
vettereddie's Avatar
Skulls, if you're still looking at the Greddy S/C, the pulley they replace on the alternator is oversized compared to stock. I believe it will actually cause the alternator to put out less total power. I was running voltage because I wanted to see what that was doing to my 1000W stereo setup. Haven't had it cut out yet but the votage does drop at idle. Fortunately, JL puts actual DC regulators in their amps so there is the same power output from 12.6V up.
I might be switching to the wideband A/F though, it will be a must if you are looking to retune without a dyno. BTW, you'll also need to rewire the Blitz S/C if you decide to go with it instead, the PE S/C claims to run with the stock ECU, not aure how they're pulling it off though. PE also uses a centrifigal instead of a Roots-type blower, might sound more like a turbo.
Old May 14, 2007 | 03:53 PM
I have the Greddy s/c just haven't installed it yet
Old May 15, 2007 | 10:23 AM
EasysBox's Avatar
dont worry about the volts, go with boost and oil if those are your two choices. a wideband would be really good to go with also, its high on my list of priorities when i get back. as is a boost and a oil pressure. good luck with your install, ;)
Old May 15, 2007 | 03:44 PM
I have decided to get the AEM digital boost and wideband gauges instead of the Cyberdynes.
Old May 15, 2007 | 04:01 PM
draxcaliber's Avatar
why would voltometer even be considered? that is something you need for a car with a big sound system, or lots of lights or something.
you need boost, egt and wideband O2 for fi applications. you can also consider oil/water temp and pressure.
Old May 15, 2007 | 05:32 PM
JSosa's Avatar
FORGET THE VOLTS!! Who cares.... Wideband, is the way to go!! This is what i have for my F/I setup, and i i think ALL of these are INCREDIBLY neccesary:
Boost
Pyrometer
Oil Press
Oil Temp
Water Temp
Wideband
rain7905643
Jun 13, 2018 05:29 AM
corbinortiz
Oct 2, 2015 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
