I was picking up a spool of speaker wire, and next to the radios they have a little monitor that shows different little things abour car audio (installing a Headunit, subs, changing speakers, running wires.) well as im watching this, it hits me, they are doing this in a tC, (ok, so i realized it when he put in the head unit and closed the door)
anybody else see this???
SL's Chief of Fail|Sheriff of Noobville|Zebra Mafia Hitman
Quote:
Originally Posted by Big_Bird
Your level of fail is astounding.
Quote:
Originally Posted by RevolutionAutomotive
I'mm happy to have inherited the fail.. I can honestly say.. I've never found more zip ties.. doing nothing.. than on this car.. Don.. You are the Zip Tie King.. Kudos to you..ha ha ha..
SL Member 16998 |12 Sonic 1.4T 90 Camaro IROC 98 Yamaha Vstar|Former Owner of the Fail Box, still here to bust *****!
I'd imagine that the tC is probably the easiest car in the world to put a system in. The entire car is held together by bolts and white clips. It doesn't get much easier!
'05 SSM tC - Totalled 9/28/07
'06 Audi A4 Quattro 2.0T 6-speed sedan - STaSIS coilovers, EVOMS Intake, APR Snub (motor) Mount, H&R 5mm/8mm spacers, blackout grill, smoked sidemarkers, GT yellow fog lights, 20% tint, RS4 Rear Sway Bar, VEI Systems Boost Gauge with Podi steering column mount, APR 93Oct. Reflash, OEM "G" DV, EuroJet PCV valve fix.
I'm always lurkin' son, ready to strike.
