Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 05-26-2007, 06:30 AM   #1
turbotc06
turbotc06 26/M
Send a message via AIM to turbotc06
Default ok need answers quick!
ok so low and behold i walked a wrx sti old school style.... so i miss shifted 4th gear slammed rev limiter ...i get back to a friends house get out of the car and I have ticking noise it sounds like its on top of the head like a valve or something ... any ideas on what it could be and how much it would be to get it fixed
wont be under warranty since its turboed ...i was only running 5.5 lbs but its the miss shift that screwed me
ideas and suggestions
-steve
turbotc06 is offline   Reply With Quote
Old 05-26-2007, 07:22 AM   #2
olaHalo
olaHalo's Avatar
olaHalo 25/M
Send a message via AIM to olaHalo
whoa. u missed 4th gear while street racing which means you were going about 80-85 and you hit the rev limit.
just checking.
Quote:
Originally Posted by olaHalo
Quote:
Originally Posted by krdshrk
watch your language.
watching
olaHalo is offline   Reply With Quote
Old 05-26-2007, 12:28 PM   #3
Dyltone
Dyltone 42/M
Send a message via ICQ to Dyltone Send a message via AIM to Dyltone Send a message via MSN to Dyltone Send a message via Yahoo to Dyltone
Probably nothing, but try to find another tC to listen to them side by side. The tC has loud "ticking" stock, and now that you are listening for it, it sounds bad.
Good luck.
Dyltone is offline   Reply With Quote
Old 05-26-2007, 02:10 PM   #4
turbotc06
turbotc06 26/M
my evap isnt hooked up we unhooked it cause its not really needed ... but taking a screwdriver to the head ...old school trick it sounds like its the second cylinder from the right ...
but we think that it might be the spark plugs too ...its a list of things i have to get into it and take it apart
and if i have to take the head off im parking the car and upgrading valve springs and seats and everything im not even going to bother fixing stock ____ ...whats the point im turboed
-steve
Old 05-26-2007, 03:26 PM   #5
pollup
pollup's Avatar
pollup 31/M
Send a message via AIM to pollup
your car is most likely fine. the rev limit is there for your motor's safety. its not good to hit it a whole lot but the chances you messed anything up are slim to none.
"Drive it like you stole it, unless you stole it"
Want to Customize Your Scion, Check out my link!!
http://www.freewebs.com/pollup/index.htm
pollup is offline   Reply With Quote
Old 05-26-2007, 09:07 PM   #6
turbotc06
turbotc06 26/M
its completely not fine lol...you hear a distinct tick coming from the top of the 2nd cylinder from the right .... my dad thinks i bent a rocker arm and yea your rev limiter is there for the motors safety...but what happens with air being rushed into the motor ....yea theres really no safety to mechanical screw up
-steve
Old 05-26-2007, 10:21 PM   #7
pollup
pollup's Avatar
pollup 31/M
Quote:
correct for that split second your car goes crazy lean, and its very possible you bent a rocker arm. inspect it or take it to a mechanic before you end up blowing the motor. but like the other guy was saying there is a ticking noise that comes from all cylinders and thats normal.
Old 05-27-2007, 01:29 AM   #8
turbotc06
turbotc06 26/M
yup welp its coming apart tomorrow morning does anyone know where i can buy better or new stock rocker arms besides a stealership
my dad really thinks thats what it is so tomorrow bright and early im taking her apart and getting new rocker arms and i need to find at least 440 cc injectors because the stock ones are the reason all of this would have came down to grenading the motor eventually so now the car is going to stay parked until i build up my motor thank god work is a 5 minute walk im going to love this summer lol
-steve
Old 05-27-2007, 02:50 AM   #9
Brett
Brett 31/M
i highly suggest that you also get a compresion check as well. i dont think that they cost that much.
Brett is offline   Reply With Quote
Old 05-27-2007, 04:51 AM   #10
turbotc06
turbotc06 26/M
well i pulled the valve cover tonight about an hour ago
i cant really tell if the cam gear towards the back of the motor is damaged but it looks like
over the piston that is causing the tapping is knocked out of place tomorrow is a new day and im going to adjust the cam so that it sits in the spot again
it looks like the cam taps on the top of the block and then goes and opens the valve ...eyeing up the cam to the valve it looks like its just a tad off and it is rubbing the head and then proceding to open the valve but i need daylight to really get into it
-steve
Old 05-27-2007, 03:16 PM   #11
turbotc06
turbotc06 26/M
ok so now i put the car back together it ran fine for about 5 minutes no obnoxoius ticking just the injectors .... after that the ticking came back ... but then i took it for a spin ... it was ticking and then it stopped ...and then it started again and then i came home parked it and its ticking again ...i dunno any ideas or suggestions before i have a shop tear the motor apart?
-steve
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
