i need TRD shocks or spring install guide.
Old May 26, 2007 | 12:27 PM
b_wet's Avatar
Default i need TRD shocks or spring install guide.
i've searched and could not find an install guide for the trd shock/struts. i know i've seen it before but i can not find it. if anyone has a link please post.
thx
Old May 26, 2007 | 01:40 PM
Mid_Life_tC-risis's Avatar
There's no install guide for just struts. You're re-doing your Hotchkis springs but putting on the new TRD struts instead of reusing the stock struts/shocks.
If you need some pics of TRD struts installed here's some links:
http://www.club-tc.com/forums/suspen...k-install.html
http://www.club-tc.com/forums/suspen...tallation.html
Old May 26, 2007 | 03:49 PM
Hat_Trick_Hokie's Avatar
^^ Yep, I just installed the exact same setup. They are a direct replacement for the stock ones, the upper pearches install with the same hardware. Make sure you put the right sides on the right, and left on the left. It could be annoying if you don't...
Old May 26, 2007 | 07:13 PM
b_wet's Avatar
bump for a better install guide.
Old Jun 11, 2008 | 06:54 PM
GammaTNT's Avatar
x2
Old Jun 11, 2008 | 10:35 PM
white-ninja's Avatar
Bump for this guy... sweet install guide i printed it out just so i can have a guide when i do, do this.
Old Jun 15, 2008 | 08:18 PM
SouLTakeR's Avatar
take apart trunk to expose rear strut bolts.
remove wheels
unbolt 19mm bolt attached to bottom of rear struts and then remove the 3 15mm bolts for each strut.
remove rear struts
Compress spring and remove rear struts and replace with new TRD struts.
Reassemble.
Remove wipers and wiper cowl to expose the front strut bolts.
Take of speed sensor wire and unbolt sway bar tie rod from both front struts.
Unbolt the two 22mm lower control arm bolts connecting the struts and unbolt the 3 14mm bolts at the upper strut tower.
Have a friend remove strut while you hold the control arm in place and ziptie it up so the axles dont pop out.
Compress srping and remove stock struts and replace with new TRD struts and reassemble.
(make sure when you remove the struts you put them back the exact way they came, use white out to mark each strut and piece them together correctly when reinstalling bushings and boots.)
DJ_FroZone
25
May 30, 2019 07:17 PM
scionlife
10
Mar 1, 2016 09:14 PM
kleecker
Jan 9, 2015 02:26 PM
randode
18
Nov 19, 2003 03:37 PM
randode
Sep 30, 2003 10:50 PM
