Exterior Carbon Fiber Kits
Old Sep 20, 2004 | 03:52 PM
FuglyxB's Avatar
Default Exterior Carbon Fiber Kits
For those of you that have installed carbon fiber kits for the exterior, a couple questions:
Did you remove the blackout tape around your doorframes before you applied the kit or did you apply the kit to taped areas?
Did you use any adhesion promoters before sticking the pieces on?
Any fitment problems? Any pieces fall off after install? Anybody in the position of having to order a single piece to replace one that fell off?
Any experiences that anyone can share would be appreciated...
Old Sep 21, 2004 | 05:15 AM
rolex87's Avatar
Are you looking to do an aftermarket piece or go with something from the dealer. I've actually got something from each. Scion did the b and c pillars. Those went on over the tape, no problems of course. I had some mirror surrounds made from edashkit.com's exterior kit. They went directly went on to the plastic. I did add some adhesion promoter, as the surface wasn't exactly perfectly flat, but they went on well, and I've had no problems with them for over 3 months now. Hope this helps!
Mike R.
rolex87
Old Oct 4, 2004 | 04:55 PM
FuglyxB's Avatar
Let me rephrase the question:
IF you were going to apply a carbon fiber kit to the door frame of your xB, would you remove the frame tape first or just apply the kit right on the tape?
Old Oct 4, 2004 | 05:08 PM
Milhamscion's Avatar
I would just do it over the tape. You shouldnt have any issues. Good luck and post some pics when your done!!
Old Oct 6, 2004 | 11:26 PM
sexyscionlover's Avatar
i did it over the tape on my xB.. worked fine and holds good. hope this helps
airmankevin1
Feb 14, 2018 01:23 PM
DebbieS
Jan 27, 2015 06:27 AM
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
scioninla
31
Jan 10, 2004 12:56 AM
