Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge
Register Forgot Password?
Reply
Old 05-28-2007, 01:45 AM   #1
MuNkY
Scion Apocalypse
MuNkY 28/M
Send a message via MSN to MuNkY
Default Vsc/Trac-Off/Cel - New problem?
So the first thing i did was search, i found plenty of threads saying that all the lights on could be the CAI, or the VVTI, or the Cam gear sensor. But ive never heard anything about the problem to go with all the lights on. I went to drive the car around the block, and it seems to be limited at 3000 rpms. Has anyone else had this problem? It also idles rough for 30 or so seconds before going back to a normal idle.
I've read through a bunch of threads and they dont really help. If possible, how do you reset the ECU? i read on one of the threads this could be the fix, but i couldnt find how to do it. Any help would be appreciated!
This all happened after i put a system in my roomates car. I've thoroughly checked everything on my end, and i cant figure out why all the lights would just come on.
/////Alpine/Rockford/Kenwood/////
Safe & Sound
Anchorage, Alaska
907-522-2353
The baddest XB in the frigid north.
MuNkY is offline   Reply With Quote
Old 05-28-2007, 02:39 AM   #2
jwaj2002
TOCC
jwaj2002's Avatar
jwaj2002 29/M
it has nothing to do with your system, its one of those three mentioned most likely its the VVTI Cam sensor, you should take it to the dealer or your local auto zone and have the ECU looked at
owner of the only FireBox
staypuffed
want to be original, don't remove the emblems, add some!
"One thing a Southern boy will never say is, 'I don't think duct tape will fix it.'" Keith Canfield Apollo 13 Astronaut
jwaj2002 is offline   Reply With Quote
Old 05-28-2007, 07:43 AM   #3
Scorpius01
Scorpius01's Avatar
Scorpius01 32/M
Befor you make any assumptions as to what the problem is, get the DTC. Also any time you get a CEL your VSC/TRAC light will also come on.
Scorpius01 is offline   Reply With Quote
Old 05-28-2007, 08:31 AM   #4
OldYeller
OldYeller 61/M
You can find the method of resetting the ECU in the Tech section:
http://www.scionlife.com/forums/viewtopic.php?t=33062
Live Long and Prosper.
OldYeller is offline   Reply With Quote
Old 05-28-2007, 08:53 AM   #5
MuNkY
Scion Apocalypse
MuNkY 28/M
It was the MAF, we found one of our friends, that had a brother that had an echo LOL.. we brought his car over, changed the MAF, and reset the car with the battery. and it worked just fine!
Safe & Sound
Anchorage, Alaska
907-522-2353
Old 05-28-2007, 08:54 AM   #6
Tomas
Admin Emeritus
Admin Emeritus
Tomas's Avatar
Tomas 66/M
tom.losh Tomas_ScionLife
Send a message via AIM to Tomas
First, find out what code you car is sending. Many auto supply stores will read the code for you for free. (Or may you or a friend have a ScanGuage or other code OBDII code drader.)
The rough idle and especially the 3000 RPM limitation indicates your vehicle is in "limp home" or "fail safe" mode due to a code.
Tom
Tomas is offline   Reply With Quote
Old 06-17-2007, 05:22 PM   #7
Darkfader
Darkfader's Avatar
Darkfader 41/M
Send a message via Yahoo to Darkfader
2 days ago my cars ecu,tracoff,CEL came on I took it to a friends house and his scan gauge II read a p0101. He cleared the code and now it is reading P0103 light wont go away. Any ideas ????
Darkfader is offline   Reply With Quote
Old 06-17-2007, 06:49 PM   #8
Tomas
Admin Emeritus
Admin Emeritus
Tomas's Avatar
Tomas 66/M
* DTC P0100 MAF Sensor Ckt. Insufficient Activity
* DTC P0101 Mass Air Flow (MAF) Sensor Performance
* DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
* DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
* DTC P0104 Mass Air Flow Circuit Intermittent
Old 06-17-2007, 08:09 PM   #9
Darkfader
Darkfader's Avatar
Darkfader 41/M
Thanks Tomas,
I went to AUtozone had them scan it and then bought a new MAF sensor and disconnected my battery and my xB is all good..
Old 06-17-2007, 08:52 PM   #10
Tomas
Admin Emeritus
Admin Emeritus
Tomas's Avatar
Tomas 66/M
:D
===> http://tijil.org/scionlife/ODBII_codes.txt <===
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
cel, idle, p0101, rough, scion, trac, vsc, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
