Are they worht it? How much of a drop do the springs give you? looking to just get my xB lowered once it gets in stock until I have the cash for my other surprise. Hit me back need to know soon thanks to all who can help
the TRD springs lower it 1". The struts might make it handle better, but wont get it any lower.
__________________ www.randode.com
Air Suspension | Lighting & LED Swaps | Metal Fab | CNC Plasma Cutting
Air Stunner Elite struts by Randode now available
*100% fabricated strut housings *KYB GR2 inserts *UA Aero Sport bags *spherical top pivots *camber adjustment *made in the USA *available for xA/xB, Gen2 xB
you may want to consider coil overs if you are thinking about replacing the strut anyway.
a coilover is a shock with a coil around the outside. the shocks are usually adjustable and also the spring is adjustable so that you can fine tune the ride height, and the dampening. this is a coilover
this is a strut and conventional coil spring
So if you use coilovers, then there are no springs on the car? It sounds like somewhere there will be an open space where something used to sit? Where are they installed too?
i got the trd springs... randy installed them :D
it definately feels better driving now and it is slightly lower. i just put on the trd 18" wheels (racing harts) and it looks like i definatly need more of a drop, maybe 2" now that i look at it, unless the springs settle down at least 1/4-1/2" more. they're really nice springs, rides really smooth and you don't got to worry about scraping.. that's for sure, it still looks like stock height almost though, 1" isn't much of a change now that i look at it.
Doc
the coilover has a spring, but its smaller in diameter than the stock spring, this can give more clearance for wider wheels. Most people use coilovers for the adjustability factor.
thanks for the install randy.
glad you like it. that had to be the easiest install ever.
how long does it usually take for the springs to settle? i hope it gets a little bit lower than what its at, the tires on these rims are so slim that it looks funky with the car not being lower than it is.
So if you use coilovers, then there are no springs on the car? It sounds like somewhere there will be an open space where something used to sit? Where are they installed too? Doc
Where do they go? Do you have any install or underbody pics that show coilovers?
look at that picture he had above... its got a small coil going around it, it's the same as you'd have with getting lowering springs, just that it's adjustable... its just that when you want to adjust them you gotta take the wheel off to get to them. if you're not going to mess with the suspension alot then you should probably just get lowering springs... coilovers are a little more rough on the ride, kinda stiff and bumpy
Hmm, I would like to have wider tires, I have 275/40/17's on the Mustang right now. But You are right, I don't want the hassle of taking tires, off, and I don't think I would do much adjusting. Why would I keep making adjustments?
iunno, if you want it lower or higher? to fine tune the height? you may buy 2" springs and it may rub, with coilovers you could adjust it a little less than 2" so it wouldn't rub. you should probably just get lowering springs and save your money for something else if you're not going to be messing with the ride height once it's set.
Coilovers are the ____. Adjustable ride height. Most have adjustable dampers. Slammed for show. Slight rake for race. Off roading? You got it. + coils are just baller. Not that that matters.
