Bag kit
Old Jul 6, 2007 | 09:03 PM
rolnlow's Avatar
Default Bag kit
would a bag kit for the 1 gen work on a 08 2nd gen xB? are all the mounts the same in the front and rear like how the coil mounts and how the front strut mounts? I am trying to find a kit for a 08 for a customer who wants there 08 xB bagged
Thanks
Old Jul 7, 2007 | 12:08 AM
morningman's Avatar
the rear would work but for the front u would hafe to get a universal air strut or you could spend he money and get the air runneer struts for the tc
Old Jul 7, 2007 | 12:49 AM
rolnlow's Avatar
would the easystreet struts work on the 08?
Old Jul 7, 2007 | 02:18 AM
moonray's Avatar
Check with Randode at www.randode.com
Old Jul 8, 2007 | 08:32 PM
eight08customs's Avatar
The universal air kit will for the Gen 1 xb will work in the gen 2 xbs. I am in the process of installing it in my car rightnow. the fronts will work even though the strut is differant, all your doing is slpping the bag over the strut and yes it does fit, the rear you have to make a new top mounting bracket in which i did fabricate already.
still comming along very slowly. Just finshed my rack for my pumps and air tank.. just have to run the lines and mount the vavles in the spare tire well. The tank and compressor is going under the car becuase i need my runk space for the Baby stroller and to carry parts and supplies.
Kit that im using is a temp kit. Its the Universal air kit for the 1st gen XB it will work with some minor adjustments. Wheni get the air runer kit ill just swap out the suspension part only and leave the rest in.
Old Jul 8, 2007 | 09:44 PM
Had to modify the rear upper mount and make a completly fabricate a new one.
this is the upper mount for the gen 1
this is the mount that i had to fabricate
this is the front bags that go right over the stock strut.
Old Jul 11, 2007 | 07:33 PM
rolnlow's Avatar
any one use this, or know if they would work on the 08 xB?
I found these rear mounts
Old Jul 12, 2007 | 02:28 AM
the easy streets wont work.. the 1st gen xb front strut is totaly diff
Old Jul 24, 2007 | 01:07 AM
randode's Avatar
Wagonistas
the sway bar link mount is on the wrong side. you may be able to switch left and right to cure this. i dont know if they will bolt in to the knuckle though.
Old Jul 24, 2007 | 08:08 AM
nope tried putting the 1st gen xb srtuts on .. not fit. The TC ones also no fit.
what might work is a Matix strut.
Old Jul 24, 2007 | 08:13 AM
here is the rear mounted
Illpost pics as soon as i do the front.. Universal air is the easiest way to go on the 2nd gen..
Old Oct 26, 2007 | 03:13 AM
rolnlow's Avatar
anymore info on kits for 08 xB or anything thanks
Old Oct 26, 2007 | 03:43 AM
rolnlow's Avatar
the rear mounts posted above would work for the rear, the front is the most questionable
cfarrrias
Mar 27, 2015 06:28 PM
kahsperr
Regional - Pacific South
Mar 26, 2015 06:25 PM
posiden
Mar 22, 2015 03:03 AM
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
yamahamx117
Dec 25, 2014 01:54 PM
