Now This Is SWEET [Perrin Lightened Crank Pulley]
Those look like they could be a cool mod. What I like about them is that they are lighter then stock, but are the same size so no underdive which might affect power to the rest of the car or screw up cam timing.
Originally Posted by hotbox05
whats the price on that bad boy
my question is will this be compatable with the echo as well ?
$134.99. Here's the link: http://store1.vividracing.com/catalo..._1844_675_2037
Originally Posted by Scion4life
How the hell would a crank pully mess up cam timing?
.Go back to school! It only drives the belts.
There is a small threaded boss behind the stock damper. It can be found around the 6 o'clock position. The boss has a 6 mm fine thread hole in it. Before you try to loosen the crank bolt, there must be a bolt installed through the damper into the boss. Without the bolt to positively hold everything in position, the balancer or crankshaft will turn as the bolt loosens. If this happens, you lose valvetrain alignment as well as crank sensor synchronization on the crank trigger. Because the 2.3 Duratec/PZEV uses no crank key way, everything is held in place by the torque of the bolt, and can move out of position without it.
He was not incorrect in his concern over screwing up timing. Essentially if the crank is out of sync with the cams, your pistons will kiss the open valves and you'll have an expensive mess on your hands. ;)
I couldn't tell you if this would be the case with the Toyota motor. It is something important to look out for though.
Originally Posted by the_saint
Originally Posted by chucksu
That looks sweet. Now all you need is a light weight fly wheel & the engine should be real rev happy.
its not gonna stall your engine I have the lightened flywheel on my car and it does help you out with the revving :D
I guess being a BMW tech for years gives me little tollerance for people who speak mech tech,with out tech knowledge.Maybe that is a fault I should work on.But regaurding the timing marks on the underdrive pully,I feel that anyone who would go through the trouble to make/machine/mass produce,and then market such a pully would take the few extra steps to ensure correct timing mark placement.Assuming the liability in selling something that if not correct could damage someones engine,I would make sure,plus Im sure they did product testing,ALL OF THIS IS A ASSUMED!!!As for the people that messed up their little fords,they messed up when they bought it!!!!!!
Now on to my next concern,realisticly,how much power do you expect to get out of the 1.5?are you gonna race,street race,blow the doors off an all motor civic wich is readilly availibe by any kid out there,NO,Face it,the only thing you will outrun maybe is other scions and maybe a school bus or two..........................
I think the focus needs to be future motor swap possibilities.I have comfirmed that the block in the scion is the same as the Celica gts,not that would be a nice way to channel money,into a swap,and custom mounts ect....not on some aluminum pully to replace your perfectly good stock one. :twisted: Ok im done,I could go on for hours! :twisted:
It's really tough talking about actual motor tech as I'd say 90% of the people on this forum are the "bling bling" crowd and really have no practical knowledge of how engines and their accessories actually work.
