Power outlets
Old 08-05-2007, 07:20 PM
KevinTxB's Avatar
Default Power outlets
So has anyone added power outlets to your box yet? I'm thinking about adding a couple right next to the cig lighter outlet. Any ideas? Pros? Cons?
KevinTxB is offline
Old 08-06-2007, 06:47 AM
BigBHaller's Avatar
Default Re: Power outlets
I think it's a good idea. There's a lot of wasted space in the center stack, and it's something that is definitely missing. Even the Matrix has one (I've always hated that car).
BigBHaller is offline
Old 08-06-2007, 08:42 AM
KevinTxB's Avatar
Should I plug into the existing cig outlet or go straight to the battery thru the firewall? I'm a noob to these things so I don't want to f anything up.
KevinTxB is offline
Old 08-06-2007, 03:57 PM
BigBHaller's Avatar
That depends on how many watts you'd like to have available. I would think that anything less than 200 watts is ok to tap into the cigaratte lighter leads. For higher watts, you'd probably want to go directly to the battery, and add some sort of relay to open the circuit when the car is off, that way you're not draining your battery. This may not be something you want to undertake by yourself if you don't understand electronics/electrical systems. I don't wholly understand it myself.
You'll probably also need to run an extension from a remote AC recepticle to the actual inverter, since you can't place that in the center stack (not cleanly anyway). I haven't found one online yet.
If all that is too complicated, you could route an additional DC plug to somewhere hidden, and just plug in an off the shelf inverter for laptops and mount it somwhere -- perhaps under the seat.
Dbonehead6
05-28-2015 12:15 AM
crystaljukebox_com
02-05-2004 05:53 AM
Quick Reply: Power outlets
