2008 xB short ram intake with Randode MAF adapter
Old 08-14-2007, 04:49 PM
Scion Apocalypse
n2htwlz's Avatar
Default 2008 xB short ram intake with Randode MAF adapter
Here are pics of the VRD short ram 05-06 tC intake with the Randode Maf adapter installed on our 08 xB.
n2htwlz is offline
Old 08-15-2007, 01:00 AM
Boxer_Rebellion's Avatar
That's exactly what I was waiting to see done... looks great!
Boxer_Rebellion is offline
Old 08-15-2007, 07:55 PM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
Very nice! Did everything just bolt right up? Had to make anything? Brackets? Feel a difference?
xbbox is offline
Old 08-15-2007, 08:14 PM
Scion Apocalypse
n2htwlz's Avatar
Need to make 1 bracket, real simple tho. There is a bit more performance and it is louder too.
n2htwlz is offline
Old 08-15-2007, 08:22 PM
KevinTxB's Avatar
it makes the engine louder or the exhaust? do you have the trd exhaust?
KevinTxB is offline
Old 08-15-2007, 08:37 PM
Scion Apocalypse
n2htwlz's Avatar
Custom dual exhaust but its gonna make the engine louder because of the removal of the air box.
n2htwlz is offline
Old 08-15-2007, 08:48 PM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
Is that the bracket on the left hand side of the 3rd pic?
xbbox is offline
Old 08-15-2007, 09:08 PM
Scion Apocalypse
n2htwlz's Avatar
No, its actually the bracket under the small round rubber insulator on the underside of the intale. The bracket you mentioned comes with the kit.
Check this bracket out, See link here ---> http://www.scionapocalypse.com/forum...hp?p=5011#5011
n2htwlz is offline
Old 08-17-2007, 01:15 PM
cincinfocal's Avatar
ona side note...i have a question about the stock intake..there is this second filter layer...this carbon or whatever insert...thats permanent in the box...there is no emissions issue with removing that? i have to read again but i thought i read something where that should not be removed...
cincinfocal is offline
Old 08-17-2007, 01:23 PM
Scion Apocalypse
n2htwlz's Avatar
If your worried about it then buy a drop in TRD or K&N filter and be done. The second layer is probably for sound resonance or has to do with squeazing out a bit more mileage but I will ask around to see what it is.
n2htwlz is offline
Old 08-17-2007, 01:58 PM
the thing is that i want an pipe intake...not this stock box..but yeah...dont know if that thing is mandatory in there for the life of the vehicle...
Old 08-17-2007, 02:32 PM
Scion Apocalypse
n2htwlz's Avatar
The whole box gets removed even if you install the TRD cold air intake too
n2htwlz is offline
Old 08-17-2007, 02:35 PM
ok..cool...gonan do the short ram set up now :D with the old tc :D nice! thanks n2htwlz
Old 08-17-2007, 02:51 PM
is this the intake you got? http://cgi.ebay.com/ebaymotors/04-05...7138QQtcZphoto
Old 08-17-2007, 03:37 PM
Scion Apocalypse
n2htwlz's Avatar
Similar but basicaly the same intake.
n2htwlz is offline
Old 08-19-2007, 04:03 PM
matt311's Avatar
looks good .. BUT your not getting cool air from right there... where that is located .. that is where the hottest air comes from the engine on the new xB....
matt311 is offline
Old 08-20-2007, 10:46 AM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
A short ram intake is not made to pull in cold air. You will only get that from a cold air intake. A short ram is designed to pull air in more quickly. Gains are roughly about the same between the two, just all depends on what look you rather.
xbbox is offline
Old 08-20-2007, 01:17 PM
Scion Apocalypse
n2htwlz's Avatar
Great answer .
I like the short ram intakes better anyways, in my opinion .
n2htwlz is offline
Old 08-20-2007, 02:00 PM
matt311's Avatar
I guess it is more about look.. because it dosnt seem as if it would pull in air much faster just b/c its shorter... but oh well.. looks nice...
matt311 is offline
Old 08-20-2007, 05:58 PM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
Deff pulls air in faster, less of a strain on the engine, less turns and bends to go through.
Example, take a straw, put it in your mouth and the other in a cup of water and suck in really fast.
Now take about 5 straws, make one really long straw with them put it in a cup of water and suck in, which one is easier?
The shorter one.
xbbox is offline
Quick Reply: 2008 xB short ram intake with Randode MAF adapter
