getting frustrated here so can we use the 1st for 2nd gen???
Old Aug 16, 2007 | 06:02 PM
bad_bhelle's Avatar
Default getting frustrated here so can we use the 1st for 2nd gen???
soory for allthe question lots of 1st gen guys told then can use the springs for 2nd gen XB let me know thanxs for all your help!!!!
Old Aug 17, 2007 | 01:29 AM
xseveredveganx's Avatar
Utah Scions
It seems (from all my lurking of this forum) that Randode is using the tC fronts and the xB rears.
I don't know about any one else, but I'm for sure getting irked by no lowering springs.
Old Aug 18, 2007 | 06:52 AM
RMS's Avatar
RMS
https://www.scionlife.com/forums/viewtopic.php?t=184402
my latest pic
Old Aug 20, 2007 | 08:27 AM
eight08customs's Avatar
Ok to answer your confusion on what springs..
Ask yourself this..
IF the TC springs or the gen 1 xb springs were made for the 2gens why isnt these companies just re labling whats already fits and selling it.
Yes it does fit and work but why is research and devlopment being done by these companies to design a spring specificly for the gen 2. Im pretty sure if it was the same spring with the same spring rates these companies wouldnt invest big money to devlope a spring that is made for the gen 2.
You have to concider many factors on why each sping is differant for each car.
Weight of car.
Weight on the front of the car.
dessign of suspension
Spring rates.
It really up to you on what you wana do. get the correct springs that made for your car or use whats made already for anouther car that fits.
hope this helps you..
Old Aug 21, 2007 | 12:01 AM
Bigfieroman's Avatar
Just backing up what Marshall said, I am an automotive/mechanical engineer (just graduated from General Motors Institute - now Kettering University), and lots of dangerous things can happen with improper spring rates. You could easily lose control of the car in an emergency, stability control or no.
Old Aug 21, 2007 | 02:27 PM
uberspeed's Avatar
Marshall, aren't you contradicting yourself with your post on cutting springs?
https://www.scionlife.com/forums/vie...asc&highlight=
You have a lot of experience customizing vehiclkes it seems, use your reputation to have folks do the right thing, the wise thing...
Old Aug 21, 2007 | 02:42 PM
RMS's Avatar
RMS
I think cutting AFTERMARKET front xB springs are fine where the spring rate is higher than the stock spring rate. Don't over do it!
Just don't what this guy did, cut rear springs?
Old Aug 21, 2007 | 02:49 PM
RMS's Avatar
RMS
As far as spring rates on the xB2 go. I am using the Gen1 Goldlines, the sprring rate is a lot higher than stock Gen1 (170F/185R). It's kind of like riding on H-Techs on the Gen1 where the SR was a little lower than stock.
Old Aug 21, 2007 | 03:54 PM
uberspeed's Avatar
I'd be concerned over using Gen1 in Gen2 for the simple reason that Gen2 is about 600 lbs heavier.
Old Aug 21, 2007 | 04:43 PM
bad_bhelle's Avatar
thanxs guys!!!!!!!! no more questions just wait.......
Old Aug 25, 2007 | 01:30 AM
JohnathonSull's Avatar
I used the stock Gen1 springs n the rear of my 08 xB, though i don't think it would drop the rear enough if you're running 18's.
prescottn
Feb 24, 2016 11:57 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
kmouse64
Jul 22, 2015 09:55 PM
dixonge
Jul 11, 2015 09:27 PM
