2008-2010 [ZSP110]
Engine vibration at 2500 rpm
Old Aug 20, 2007 | 12:58 AM
Boiiinng's Avatar
Default Engine vibration at 2500 rpm
I just purchased my first Scion, the xD. The only annoyance I have noticed is an engine vibration that I can only feel at my feet, on the floor board, and only at around 2500-2600 rpm. It becomes cyclical (2/sec.) at 65mph, and that's where it's annoying as that's the typical highway speed I cruise at. I've never had a VVT before, so I am wondering if this is usual for this type of engine or if I should take it in to have something checked out?
Old Aug 20, 2007 | 02:01 AM
Kremtok's Avatar
That doesn't sound normal to me. Since it sounds like you have it pretty well pinned down, it should be easy for a tech to reproduce and diagnose. Take it into the dealer - use that warranty, baby!
Old Aug 20, 2007 | 12:50 PM
zoltiz's Avatar
N.G.S.O.
All my Toyotas were pretty smooth. Small 4-bangers are noisy, but no weird vibrations. Any chance of it being wheel balance?
Old Aug 20, 2007 | 02:04 PM
Deadduck's Avatar
You packing an MT or AT in the transmission? Sorry if I missed that fact somewhere in the posts!!!
Old Aug 20, 2007 | 04:48 PM
Boiiinng's Avatar
It's all factory. I've done nothing to it.
Old Aug 20, 2007 | 04:50 PM
Boiiinng's Avatar
No, it only happens when the accelerator is depressed at those RPMs. When going downhill, the cruise lets up on the accelerator, so no noise.
Old Sep 30, 2007 | 07:46 PM
Boiiinng's Avatar
By the way, I solved it. Tire pressure was the culprit. I didn't even realize they were low until my warning light came on. As soon as I filled them up to spec, the vibration was gone. Since the vibration started right after I took it off the lot, this means that the dealer didn't even have the tires aired up properly. The light came on when they dipped below 30psi and the max is 51! You might want to check your own if you haven't yet.
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
k1114
Nov 30, 2014 01:40 AM
eric_m
79
Mar 17, 2013 12:21 AM
Phillip_Injen
53
Jan 17, 2004 01:56 AM
