Official Supercharger Information Thread
Old 08-29-2007, 05:15 PM
kikcaffine's Avatar
Default Official Supercharger Information Thread
*Do Not Edit*
Information Bellow
kikcaffine is offline
Old 08-29-2007, 05:20 PM
kikcaffine's Avatar
General Info
Vortec V5 F-Trim
Straight cut spur gear
Fits engines up to 475 horsepower
Maximum airflow: 700 CFM *
Maximum boost pressure: 20 PSI *
Absolute maximum impeller speed: 65,000 RPM
Adiabatic efficiency: 76% **
Available with straight discharge and clockwise or counter clockwise rotation
Stock Injectors are 380cc
TRD Injectors are 410cc
BPV’s
Forge 007
TurboXS Type 25
Bosch 110
Any internally recirculating BOV
50/50 Hybrid’s- Forge Hybrid, Go Fast Bits hybrid, Ebay Dual Blow off with recirculating.
NO FULLY ATMOSPHERIC BLOW OFF VALVES- Will cause a lean setting when you shift, the MAF needs the air to recirculate back through it so it can get a proper reading.
Belts
Gates K070890
Use that one, the Goodyear Gatorback has a very bad tendency to slip
For use with the 9.5 Pound Pulley
Pulleys
NST 9.5 Pound Pulley
http://www.dezod.com/pd_nst_trd.cfm
Intakes
DO NOT USE WITH OUT A TUNE YOU WILL RUN LEAN
MMW Supercharger Intake
Umnitza Carbon Fiber Intake
Hybrid Cold Air Intake
ARC Cold Air Box
You can cut out the hydrocarbon filter that is on the top of the adapter that makes your airbox lid fit on the TRD supplied airbox bottom. Cutting this huge white screen out makes for about 1-2 WHP and increased throttle response.
Spark Plugs
The plug to use with the supercharger is the Denso Ik24 gapped to .040
Its 2 steps colder than stock and 1 step colder than TRD spec’d one
Rebuild Info
Bearings-
For the impeller shaft bearings
2 Nachi ball bearings nac-6003 (must be speed rated to 65000 RPM)
For the main input shaft bearings
2 SKF Ball Bearings 6205/C31
End Part / shaft assembly....
There are two end bearings part number 6205 2rs
Seals-
25-40-7 is the metric size of the shaft seal.. Timken part #222540
Taping Boost Gauge Line
Tap the line for the boost gauge rite after the Vac line from the throttle body, but before it gets to the T-Fitting for the ByPass Valve and you will get a much better reading.
Catch Can Related
On the intake manifold you have a traditional breather hose that comes off the valve cover into the intake manifold. And another into the intake. Cap off the manifold and route your breather line to a catch can or back into the intake "I prefer a catch can to keep the intake assembly clean and keep buildup from happening on your intake valves and ports." Also oil vapor lowers octane which can cause your engine to pull timing and then a loss of power if it senses knock". The best part about fixing these issues is you will gain throttle response and I gained around 1-1.5 psi across the board which means I was most likely leaking a small amount of boost back into the intake.
Turbo Timer-
I would reccomend getting a timer so it keeps your car running and cycles the way hot oil out of the supercharger. It takes about 10 minutes to install, and costs about 100 dollars for a new one. Or you can stay in your car for 30 seconds extra, either way your call.
Ecu Reflash-
It must get done, and it must get done at Toyota. Its not something every dealership can do, due to needing a special software tool. It is tuned very very conservatively and you can run a 9 or 9.5 pound pulley with no problems on the stock supercharger fuel map.
People have gotten about 230whp with the stock pulley though with just a retune on a Unichip Engine Management, so that’s always an option aswell.
Noises
Whine. The supercharger whines, it whines at idle, midthrottle, and under full throttle. It’s a fact of life and you need to accept that’s what it does. If you hear a put put put put noise at idle that’s the BPV getting stuck open.
Intake. If you get an intake you will hear your little BPV hiss whe your shift, that’s the only way to hear a hiss unless you get a Hybrid BPV.
Oil
Toyota recommends between 4.0-4.8 quarts of 5w30
I personally run about 4.5 quarts of 10w40 so it wont leak as easily because it’s a bit thicker than the 5w30
Boost Levels in HKPA via Digital Boost Gauge
-.58-.60 at idle in neutral (VAC)
-.70 coasting in gear (VAC)
.60 (8.7PSI at 6000rpm)
.62 (9.2PSI bouncing off rev limiter)
Install Manual
2005-2006 Supercharger Installation Manual
http://trdsparks.com/install/PTR01-21050-90inst.pdf
2007-
http://trdsparks.com/install/PTR41-21070inst.pdf
Part Numbers
TRD, Supercharger Compressor Housing Bracket Replacement Part PTR01-21054
TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB
TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD
TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00
TRD, Spark Plug PTR24-21055-01
TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060
TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060
TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050
TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051
TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052
TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053
TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054
TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055
TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056
TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057
TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058
TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059
TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060
TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061
TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062
TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063
TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064
TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065
TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066
TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067
TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068
TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069
TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160
TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161
TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162
TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163
TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164
TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165
TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166
TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167
TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168
TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169
TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170
Power Out Puts
~195 WHP for a 5speed stock
MAINTENANCE
Every 3k miles unscrew oil inlet nozzle and blow out with high pressure air in the direction of the screen (into the nozzle)
EVERY GAS FILL UP check your OIL level every time.
Rebuild INFO thread:
https://www.scionlife.com/forums/viewtopic.php?t=215404
Old 08-29-2007, 06:29 PM
Stone128's Avatar
MAINTENANCE
I can't remember where I read it, but someone said they had called TRD and specifically asked about this recommended maintenance and TRD said this was a typo and it was meant to be 30,000 miles. This makes a lot more sense to me but I can't confirm this to be true. Good write up though!
Stone128 is offline
Old 08-29-2007, 07:02 PM
jjos1's Avatar
You can also use nachi 7003 speed rated bearings, same bearing just different part#.
jjos1 is offline
Old 08-29-2007, 07:20 PM
Team Hamster
BLUEMEANIE's Avatar
Default Re: Official Supercharger Information Thread (LOTS OF INFO)
Originally Posted by kikcaffine
...Straight cut spur gear...
its got Helical cut drive gears, as opposed to straight cut gears.
BLUEMEANIE is offline
Old 08-29-2007, 07:24 PM
kikcaffine's Avatar
Not according to their website!
http://www.vortechsuperchargers.com/...s+Supercharger
Old 08-29-2007, 08:59 PM
ScottTc13's Avatar
This thread below has extremely valuable information in it also. It has really great pics of the SC torn apart and a lot of good info in general. A ton of reading though, but informative.
https://www.scionlife.com/forums/vie...065&highlight=
Also, this is where the discussion was about the 3,000mi oil screen cleaning. I am glad to hear that 30,000 is recommended.
x4 stick it
ScottTc13 is offline
Old 08-29-2007, 09:57 PM
Stone128's Avatar
Don't take my word that it is really 30k. I just remembered hearing that in a post but it could be wrong.
Stone128 is offline
Old 08-29-2007, 11:26 PM
kikcaffine's Avatar
Mine is essentially the condensed version of that posting.
Old 08-30-2007, 01:16 AM
jjos1's Avatar
Has anyone have the speed rated bearings fail ? I remember hearing about pulley bearings but never the speedrated ones.
jjos1 is offline
Old 08-30-2007, 03:29 AM
Team Hamster
BLUEMEANIE's Avatar
hmm... toyota's site says they're helical cut drive gears, as opposed to straight cut gears to reduce noise. I even cut/paste'ed it from trdsparks cause I had to double check.
Could be a typo or it could be something Vortech did for toyota so it would be quieter for daily use for the normal average consumer. ???
Old 08-30-2007, 01:00 PM
jjos1's Avatar
they are helical cut drive gears
This was from garage's thread
jjos1 is offline
Old 08-31-2007, 12:57 PM
ziobep's Avatar
WHERE CAN I ORDER THIS REBUILD STUFF FROM????????
Rebuild Info
Bearings-
Seals-
ziobep is offline
Old 08-31-2007, 01:22 PM
cessblood's Avatar
I think someone made another thread like this before.
cessblood is offline
Old 08-31-2007, 03:38 PM
Nychold's Avatar
Is there any advantage to straight cut gears over helical gears?
Nychold is offline
Old 09-01-2007, 06:37 PM
Sleep3r's Avatar
hey kikcaffine why dont you add info like:
bird chirp noises / chattering are normal at idle
muffling / wooooooo sounds at about 3k rpm +/-are cause by OEM BPV are normal
and state the normal pressure numbers for vac at idle and air/fuel (i dont know that)
Thank you
Sleep3r is offline
Old 09-01-2007, 06:51 PM
kikcaffine's Avatar
Ok I will, Im actually about to make a revision in the next week
Old 09-04-2007, 06:21 AM
GammaTNT's Avatar
After installing S/C, do i have to add more than 4 quarts of engine oil? or 4 quarts should be ok? I thought the S/C use the engine oil to lubricate, so i might need more/
GammaTNT is offline
Old 09-04-2007, 03:28 PM
Sleep3r's Avatar
i put 4 and a half quarts
Sleep3r is offline
Old 09-04-2007, 03:55 PM
kikcaffine's Avatar
Like wise, thats also in the revision. LOL
Quick Reply: Official Supercharger Information Thread
