GETTING THESE ROTORS OFF MY XB????
Old Oct 17, 2004 | 01:56 AM
wavedoc69's Avatar
Default GETTING THESE ROTORS OFF MY XB????
HOW THE HELL DO I GET THAT FRICKIN BLACK NUT OR BOLT OFF OF THE SPINDLE IN ORDER TO GET THE ROTOR OFF!!! IT KICKED MY ___! I STRIPPED THE ____ OUT OF IT. I GOT SOME FAT ROTORS FOR THE XB BUT I COULDN'T GET THAT SPROKET LOOKING BOLT OFF OF THE ROTOR...
PLEASE HELP!!!!!
Old Oct 17, 2004 | 02:07 AM
dgHotLava's Avatar
what?!?!?!?!?
remove the lug nuts,
remove the tire,
remove the caliper bolts,
remove the caliper,
the rotor falls off on it own...
that nut you're describing is the spindle nut, keeps the bearing in place.
if you really f'ed it up that bad, you should have a pro take a look at it and make sure it is still safe!
Old Oct 17, 2004 | 02:11 AM
wavedoc69's Avatar
Default DAMN...
are they replaceable? thanx for the tip!!!
Old Oct 17, 2004 | 02:31 AM
dgHotLava's Avatar
yes it's replaceable.
you need to make sure the bearing behind it is still intact (packed with grease).
put on a new nut, and tighten (not too tight or the wheel wil not rotate)
oh, the nut might be a left-hand thread (meaning if you thought you were loosening it you were really tighting it)
if you have this nut off, DO NOT DRIVE THE CAR.
if the nut is still there, have someone check it out when your done.
if the nut is too tight you will ruin the bearing, and the wheel will not spin easy.(it will pull to a side)
Old Oct 20, 2004 | 10:51 PM
black_xb's Avatar
yeah what sprocket looking thing? There are 2 bolts on the calipper and 2 on the calipper bracket. thats all you have to remove...
dougcbx
Oct 23, 2015 11:42 PM
blackpearlTC
Jul 19, 2015 04:55 PM
Dargor5
Jun 24, 2015 06:43 PM
cquencebrakes
Jun 23, 2015 09:42 PM
