Rim size question.........
Old Dec 30, 2003 | 03:43 AM
Munch's Avatar
Default Rim size question.........
Would a 18x8" rim fit on a xB? If so what would be the correct offset and tire size?
Old Dec 30, 2003 | 10:04 AM
ShadowMage's Avatar
They'll fit but depending on the offset you get (according to what I've read) you'll get some rubbing. Here's some links on the topic:
https://www.scionlife.com/forums/vie...highlight=18x8
Old Dec 31, 2003 | 12:52 AM
ScionVan's Avatar
Sure, an 18x8 will fit... do you want to put it on the front or rear? Front? +30mm to +32mm offset. Rear? +25mm to +30mm offset.
Tires... 215/40-18 will work, as will 215/35-18.
Old Dec 31, 2003 | 12:55 AM
Munch's Avatar
Will they rub with the Tanabe springs (2.2-front - 2.0 rear)?
Old Dec 31, 2003 | 12:58 AM
jjambox's Avatar
will the 215/40/18 rub w a 2in drop?
Old Jan 3, 2004 | 05:18 AM
Besk_one's Avatar
it shouldn't have any rubbing issues 215/35/19" fits with little problems and 215/40/18 has a shorter overall sidewall, so you should be all good
i'm going with 215/40/18 on a 18x7.5" wheel +42 offset, running a 5mm spacer in the back (maybe a 5mm in front and 10 or 15mm in the back, but i'll see what it looks like with the 5mm in back first)
i should have them on by next weekend, i'll post up some pictures as soon as i can
oh ya, spfr jon has 18x8" wheels +45 offset, and they fit on his car - he has to run a 5mm spacer in the back and he had to do a little trimming on his ride, but it was only minor and he's driven cross country with those wheels, so even the higher offsets will work, but it's going to be more drama - try and get the lower offsets if possible!
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
Genesis
64
Jan 22, 2005 01:02 PM
