Replacing Stock Head Unit
Old Oct 20, 2004 | 01:28 AM
markandersen's Avatar
Default Replacing Stock Head Unit
I have just ordered my new head unit and am looking foward to getting it. However, I was just wondering if you guys could help me out with how to get the old one out.
I am sure I could find out somewhere online but if someone just did or something could you let me know how to get the old out and the new in.
I think I am ok with the harness and dash kit I need, but once I get my deck I will be very anxious to get that thing in there.
Pics would be wonderful!
Old Oct 20, 2004 | 01:33 AM
chadfo's Avatar
It's a snap. Pull off all three temperature control *****. There will be a screw behind the left and right ****. Unscrew those and the whole center section just pops out. I've had the best luck by pressing down and pulling out at the top just inside of the vents. Once that's off there are just 4 screws holding the head unit in. I think you can take it from there.
Old Oct 20, 2004 | 01:35 AM
wow that was fast, thanks for the fast response....hope no one else (thieves) know how easy it is to take it out.....
thanks again I appreciate it...
Mark
BoomBox757's Avatar
DelMarVa
1.)pull the ac ***** off
2.)unscrew both the right and left screw
3.)at the top, push down on the silver while pulling out at the same time
4.)if that doesnt work pull from the bottom
5.)if that doesn't work your being a _____ pull harder
6.)once its off disconnect the ac and hazard lights and stuff from the back
7.) set that piece aside
8.)unscrew your old head unit and its out, you just have to unhook everything behind it
Old Oct 20, 2004 | 01:37 AM
can't believe how fast I can get answers...preciate it guys....shouldn't be too bad, I will post pics when I get it done.
Mark
Old Oct 20, 2004 | 01:38 AM
BoomBox757's Avatar
DelMarVa
damn thats what happens when you leave a reply window open, hope mine gives some more detail. its really easy. i think i've probably done it atleast 50 times
Old Oct 20, 2004 | 01:43 AM
chadfo's Avatar
Yep. The hardest part is getting the plugs off.
Old Oct 20, 2004 | 02:55 AM
ikhonlord's Avatar
The first couple of point in the following FAQ will show you the things that you have to remove and unscrew. Hopefully everything goes fine:
https://www.scionlife.com/forums/viewtopic.php?t=23214
Locked! :D
billzor
Scion tC 2G ICE & Interior
Jan 17, 2015 12:38 PM
linlow
Scion tC 1G ICE & Interior
Dec 14, 2014 12:56 AM
lunchbx05
Dec 11, 2014 06:13 PM
ToyTuners
Feb 22, 2004 10:34 PM
sci-bionic
19
Dec 11, 2003 03:35 AM
