18x8.5 & 18x.9.5 Setup
Old Oct 10, 2007 | 01:50 AM
danscreations's Avatar
Default 18x8.5 & 18x.9.5 Setup
Looking into a set of staggered wheels and been look around like crazy tring to figure out if they'll fit or not. Looks like the fronts will be fine but not sure on the rears and what tires to use.
18x8.5 et35
18x9.5 et35
Tires???
225/40/18
245/35/18
Old Oct 10, 2007 | 08:58 AM
eight08customs's Avatar
should fit but im the kind of person that will make it fit if it dont fit..
Old Oct 10, 2007 | 06:55 PM
IowaSciontist's Avatar
If it's an '08, you should be fine. I know a guy running 18x9 +32 F and 18x10 +38R with no rubbing. Dropped 2".
Old Oct 10, 2007 | 07:33 PM
What size tires are you running?
I got the exact wheel and tire were going to test fit it tomarrow so I'll take some photos and post for those of you interested.
Old Oct 11, 2007 | 01:54 PM
He never otld me what size tire it was. I would guess 35 series, They look pretty low profile.
Old Oct 12, 2007 | 04:17 PM
NoLimitzBuilt's Avatar
Team No Limitz
I am running 19's with 19x8.5 and 19x9.5 with a +38 offset. I am running a 235-35-19 and then a 245-35-19.
Old Oct 12, 2007 | 06:11 PM
thanks for the replies! I wound up getting one wheel to test fit with a 255/35/18 tire and everything fits perfect. The car's not lowered if so I might go with the 245/35/18 rear. I think i'm going to run 235/40/18's front. Looks greats! Thanks Again!
Old Oct 19, 2007 | 03:19 AM
wanted to give you all an update and I hope mike the owner of the XB post some photos but worked out perfect. wound up running 225/40/18's front and 255/35/18's rear as they're the same overal diameter and the 235/40's would have been a bit taller on the front. the XB is at stock ride height right now but there is no rubbing what so ever and drives great. The wheels both front and rear are flush with the fenders so If he lowers it with the slight strech of the tire should clear perfect.
Old Oct 19, 2007 | 12:25 PM
madpb's Avatar
Just go my new rims on from danscreations . They look great.
I snapped a few pics (I am not very good with a camera) but here they are.
Old Oct 19, 2007 | 01:28 PM
itsyounotme's Avatar
Very nice. Do you plan to lower it?
Old Oct 19, 2007 | 04:04 PM
madpb's Avatar
now that I see how it looks I think it would be a good idea.
Old Oct 20, 2007 | 07:36 PM
Here ya' go mike!
Old Nov 1, 2007 | 12:49 PM
jpauletteUSAF's Avatar
Well, I had been thinking about getting that same setup, so now I guess I know what they'll look like. And now, I want them more.
Old Nov 3, 2007 | 02:07 AM
john08xb's Avatar
Why are you guys staggering the wheel sizes?
Old Nov 3, 2007 | 02:37 AM
uberspeed's Avatar
Make them sit more flush.
Old Nov 8, 2007 | 02:07 AM
jelder11's Avatar
So what is in this picture is a 225/40/18 front and 255/35/18 in the rear and your wheels are 18x8 and 18x9 what drop springs did you use
Old Nov 8, 2007 | 11:33 PM
madpb's Avatar
your correct on the tire sizes. The rims are 18x8.5 and the rears are 18x9.5 Stock springs.
Old Nov 9, 2007 | 12:17 AM
jelder11's Avatar
What springs do you plan to use.. And when you lower it is it fender flush going to hit the fender wel
Old Nov 25, 2007 | 11:20 PM
madpb's Avatar
I just ordered the tanabe's (DF) the one with the greater drop.
(1.7 front and 2.1 back) and I order the front and back Hotchkis sway bars.
Should look good and handle well too.
Old Nov 26, 2007 | 01:26 AM
bad_bhelle's Avatar
[img]
18x8.5 and 18x9.5 45 offset....tanabe df dropped 225-40-18 235-40-18 rears[/img]
