CEL eliminators, antifoulers, and O2 simulators
Old 10-13-2007, 05:07 AM
theracingrhino's Avatar
Default CEL eliminators, antifoulers, and O2 simulators
So when it comes to these new high tech engines I'm pretty much lost. all my wrenching and tuning experience is pretty much with old school carbed motors. So here's the noob question what are CEL eliminators, antifoulers, and O2 simulators and how do they work?
I understand the sensors a bit just not how to work around them...
theracingrhino is offline
Old 10-14-2007, 08:08 PM
superwhitescion's Avatar
http://weapon-r.com/english/index.ph...oducts_id=6219
superwhitescion is offline
Old 10-14-2007, 09:45 PM
I've checked that out on weapon-r's site before. That little blurb of info doesn't say if it is just an extension from where the sensor would usually screw in or if it is something different. That is more the nature of my questions. I understand that exhaust pressures and o2/oxygen ratio's are what throw a CEL. Is an anitfouler just something inside an exhaust to buffer the flow of gasses? Is an o2 simulator a card something that plugs into the computer to trick the car into not turning on a CEL? To anybody who knows the answer to these questions i would apriciate some help.
Old 10-16-2007, 04:54 PM
Team No Limitz
NoLimitzBuilt's Avatar
I have used the Weapon R one in my tC and in my second gen xB now. They are the only one that I know of that has worked 100% of the time. I tryed the antifoulers and they didn't work. I say the weapon R for sure.
Here is what it does. When you do a header, the 1st and 2nd O2 sensor read the same reading. By moving the 2nd O2 sensor out of the loop alittle it reads a different reading and keeps the CEL off.
NoLimitzBuilt is offline
Old 10-17-2007, 12:58 AM
Cool man thanks! :D
Old 11-10-2007, 12:26 AM
Scorpius01's Avatar
There seems to be a little confusion here. The xB pre cat sensor is an A/F ratio senor not an O2 sensor. An A/F sensor has better control of the fuel delivery, then an O2 sensor.
With an O2 sensor pre cat the signal it produces is very fast, bouncing from rich to lean conditions, with a varied voltage .if the secondary post cat 02 follows this pattern on this type of setup a P0420 cat below efficiency code will be set.
The ECU will see this wave form and interpret this as too much oxygen in the exhaust stream.
An A/F ratio sensor no longer bounces from rich to lean, it will produce a certain voltage based on the actual oxygen content and maintain that voltage until the oxygen content changes. The post cat voltage should move really slow, in a very lazy manner.
If the post cat O2 gets too active a P0420 code will be set.
An antifouler places the secondary O2 further away from the exhaust stream. An O2 simulator is just a chip that plugs into the connector for the O2 and simulates a good secondary O2 wave form so the ECU does not throw a CEL.
Soldering a resistor on the secondary O2 signal wire produces the same effect.
Scorpius01 is offline
Old 11-10-2007, 01:05 PM
Originally Posted by Scorpius01
There seems to be a little confusion here. The XB pre cat sensor is an A/F ratio senor not an 02 sensor. An A/F sensor has better control of the fuel delivery, then an 02 sensor.
With an 02 sensor pre cat the signal it produces is very fast, boucing from rich to lean conditons, with a varied voltage .if the secondary post cat 02 follows this pattern on this type of setup a P0420 cat below efficiency code will be set. The ECU will see this wave form and interrpert this as too much oxygen in the exhaust stream.
An A/F ratio sensor no longer bounces from rich to lean, it will produce a certain voltage based on the actual oxygen content and maintain that voltage until the oxygen content changes. The post cat voltage should move really slow, in a very lazy manner. If the post cat 02 gets too active a P0420 code will be set.
An antifouler places the secondary 02 further away from the exhaust stream. An 02 simulater is just a chip that plugs into the connector for the 02 and simulates a good secondary 02 wave form so the ECU does not throw a CEL. Soldering a resistor on the secondary 02 signal wire produces the same effect.
This is the kind of info i was really looking for! i apriciate the clarity.
Old 11-12-2007, 09:23 PM
tc1stgen's Avatar
Hmmm...I need one of these!
tc1stgen is offline
Old 01-06-2008, 09:16 AM
eight08customs's Avatar
OK so this goes on the Header side or after the header? Ihave never had to use one of these but i wana make sure I have it before I install my header in my 2nd gen..
eight08customs is offline
Old 01-08-2008, 02:01 AM
healthynine's Avatar
it goes after the header to prevent a P0420 code which basically indicates a problem with your cat.
healthynine is offline
Old 01-08-2008, 02:46 AM
Team No Limitz
All you do is take out the second 02 sensor. Put in the CEL eliminator peice, put your sensor back in the CEL eliminator and you are set. It is not hard to do. Takes about 10-15 minutes.
Old 01-14-2008, 02:50 PM
afi123215's Avatar
How do i check to see if my 02 sensor is still working? I did the antifouler trick and the CEL came on within 30 miles. I need an inspection sticker at the end of the month, PLEASE HELP!!!
afi123215 is offline
Old 01-14-2008, 10:44 PM
Got mines todya from NOlimitz.. that thing came supper fast!!! thanks man
Old 01-14-2008, 10:46 PM
man its pretty simple part.. I could have made this at work...
I would figure it would have had a orifice inside but its just a 90deg tube with threads...
Man who ever though of this was smart!! to comeup with something so simple..
Old 01-14-2008, 11:07 PM
cee_dub2003's Avatar
remember guys the CEL Eliminator is adjustable. Sometimes if the CEL is tightened too far inside the O2 bung the CEL might come on. Just back it out a little so that the tip of the CEL isn't too far inside the exhaust gas flow.
cee_dub2003 is offline
Old 01-07-2013, 09:47 PM
rcsnipe2000's Avatar
anyone have a pic of what these guys look like??? im kinda confused is it a o2 sensor or a adaptor that the o2 sensor screws into? or a chip or whatever that plugs into the conector?
im asking because i have already changed the o2 sensor and had a aftermarket cat installed.
light was off for about 2 or 3 months after the new cat, but its back on and same code.
any help would be apreciated.
thanks,
rc
rcsnipe2000 is offline
Old 01-10-2013, 04:05 AM
xtylerx's Avatar
Here's the Weapon-R eliminator.
Short end screws into the bung on the s-pipe, o2 sensor goes in the other end.
xtylerx is offline
Old 02-13-2015, 09:49 PM
Bluexb2's Avatar
Default Will the weapon r cel eliminator work with any header?
Will the weapon r cel eliminator work with any header or does it have to pair with the weapon r header?
Bluexb2 is offline
Joe_Dezod
152
05-23-2013 08:59 PM
89db-
10-08-2008 02:05 AM
Joe_Dezod
45
08-24-2008 12:39 AM
TongMan
44
03-15-2007 10:07 PM
bluenjsciontc
30
09-04-2005 03:06 AM
Quick Reply: CEL eliminators, antifoulers, and O2 simulators
