Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 10-18-2007, 05:15 PM   #1
Blue_TC_Man
Blue_TC_Man 25/M
Send a message via AIM to Blue_TC_Man
Default stock internal boost level
I'm thinking about building a custom turbo kit, and before I get started I was just wondering what you guys who are turboed would say is a safe amount of boost for a stock engine? I'll of course install fuel stuff and it ill be tuned, but Im more interested in what the stock internals and bottom end can handle.
Thanks in advance.
custom turbo set up 8.5 psi
297whp 287wtq
Thanks to my Sponsors:
www.gatorz.com
www.tekbolt.com
Blue_TC_Man is offline   Reply With Quote
Old 10-18-2007, 05:51 PM   #2
flint_08
flint_08 30/M
I think I remember seeing someone running 14 pounds, but I wouldn't do that for too long. I would stil with 12 or less.
| 2008 Scion tC - FM | TRD Axle-Back Exhaust | VRD Grilles | S2K Antenna | VRD Fogs | Raceland Coilovers | Raceland Strut Bar | HIDExtra 6000K
flint_08 is offline   Reply With Quote
Old 10-18-2007, 05:52 PM   #3
Joe_Dezod
Joe_Dezod's Avatar
Joe_Dezod M
Send a message via AIM to Joe_Dezod
Depending on your tune and fuel type, i wounldn't reccommend more than 10 for daily driving, and 11-13psi for the track or dyno pull. Even that's pushing it.
Any power goal you have in mind?
DEZODWEST.COM - The performance gurus!
A PROUD member of NASA, SEMA, and ScionLife!
joe@dezodwest.com
Joe_Dezod is offline   Reply With Quote
Old 10-18-2007, 05:54 PM   #4
flint_08
flint_08 30/M
And search, this has been discussed many a times:
One example:
http://www.scionlife.com/forums/view...tock+internals
Old 10-18-2007, 06:16 PM   #5
TCpete
TCpete's Avatar
TCpete 111/M
i think anything over 300 is starting to push it... 230-280 is a good chunk of power to be dealing with ... asuming u want a long term or reliability aswell
COMING 2012: redefining function over form
MY BUILD THREAD!BBS LM restoration thread
TCpete is offline   Reply With Quote
Old 10-18-2007, 06:34 PM   #6
flint_08
flint_08 30/M
Quote:
I think he meant boost wise, not HP. But he is more than welcome to try and put 300psi into that 2AZ all day long!
Old 10-18-2007, 06:38 PM   #7
Blue_TC_Man
Blue_TC_Man 25/M
Thanks for the link i searched a few times but got a bunch of random things. As for power I'm just looking to hit a steady mid-low 14. I was thinking about 8psi, but Im used to driving a mustang so over 7psi was pushing it. So I figure 8 would be a good bit of performance and be reliable from what I've read.
one more question though does anyone know how strong our blocks are? I dont see any need to stud the lower end or beef up anything but if anyone has experience opinions would be great.
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Old 10-18-2007, 06:51 PM   #8
flint_08
flint_08 30/M
8lbs wont be an issue with a good tune. There are a lot of people on here running 8lbs + on stock internals daily.
Old 10-18-2007, 06:56 PM   #9
TCpete
TCpete's Avatar
TCpete 111/M
8psi on 1 turbo is not the same as 8psi on another turbo...size of housings/turbo vary...8lbs on a 16/18g is no the same as 8lbs on a gt30 or larger turbo... since he is going custom no one knows what he will make on 8lbs because we dont have enough info.. going on lbs of boost alone is very broad.
im pretty sure thats why Joe asked what his goals in pwr are... that can is a factor in deciding what kind of turbo mostly like he will be using.
Old 10-18-2007, 07:07 PM   #10
ScionGT35R
ScionGT35R's Avatar
ScionGT35R 34/M
^^ X2
Use HP not boost.
Sponsored by StreetTuners
Tuning and build by Mecanica Pito ( You already know him)
Custom turbo 511whp@23 psi on pump gas and 19" wheels.
Coming back soon!!!!!!!!
Whit new mods.
ScionGT35R is offline   Reply With Quote
Old 10-18-2007, 07:16 PM   #11
Blue_TC_Man
Blue_TC_Man 25/M
well im thinking generically i usually dont like to set hp goals since te goal can change a project from doing it reliably to doing it sloppy. I would rather have a 220hp car that would last 100k+ miles vs a 300hp car that will blow in 50k. It seems that 8 is a common DD psi so thats probably how i'll go and possibly a bit more at the track, I just dont wanna end up warping a head or blowing a rod sky high in a system i thought could handle more
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Old 10-18-2007, 07:52 PM   #12
TCpete
TCpete's Avatar
TCpete 111/M
you can always have a low boost and high boost setting.. -5-6 lbs low boost.. 8-9 lbs or 10 for high boost
Old 10-18-2007, 08:02 PM   #13
flint_08
flint_08 30/M
EASY! It was a joke based on your response.
Thank you, I don't need a lesson on turbocharging.
When you are dealing with larger numbers I agree there are more factors involved. One could assume that he is likely going with a T3/T4 setup (maybe not?) and 8lbs on stock internals with a good tune is fine for daily driving.
Old 10-18-2007, 08:05 PM   #14
Blue_TC_Man
Blue_TC_Man 25/M
yeah Ive thought about that, but that gets into expensive tuning and installing a boost controller, and an expensive one at that since I would want to go electronic since manual controllers are just annoying. I'm in college so this is a long term very budgeted build, and looking for as many sponsors as possible to complete it faster. I'm just trying to get design notes and some solid numbers so i can make a proper presentation to companies so they will know I am serious.
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Old 10-23-2007, 12:00 AM   #15
redrumtc
Strictly Scionized
redrumtc's Avatar
redrumtc 32/M
It matters what ur set up is going to be with the right custom kit 10psi should do I am getting mine custom made and were going to do 10psi to 11 psi and a dyno push at 15psi for turbo mag and were hopeing for 300 plus on 10 psi. The 15psi is for looks. I will post my # up as soon as the cars done it should be next week.
Sean S
my sponcers/scion parts sales
http://www.sikky.com/ Scion Parts
http://www.jeimportperformance.com/ Scion Parts
www.myspace.com/speedesign Custom Graphic
(2005 Sikky Scion Tc 8psi 303whp 294lbft)
{NEW SIKKY #s SCION TC 8PSI 308whp 295LBFT}
redrumtc is offline   Reply With Quote
Old 10-23-2007, 12:09 AM   #16
Blue_TC_Man
Blue_TC_Man 25/M
Quote:
awesome what kind of turbo are you going with I am kinda stuck on either the greddy turbo charger used in there tc kit (cant remember the numbers ATm) or the garret GT2554R
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Old 10-23-2007, 12:23 AM   #17
redrumtc
Strictly Scionized
redrumtc's Avatar
redrumtc 32/M
gt30 they picked it out for me. how much would u like to spend on a full blow turbo set up and with that power along the lines u mit want to get half shaft made and a clucth & flywheel if u want to do little things with it a walbro fuel pump to go with injectors that u get it goes for about a 120$.what kind of exst are u going to run?and also what kind of manifold. I am new to the turbo thing a love n/a but magz dont want n/a plus i want a sti killer and srt4 killer
Sean S
Old 10-23-2007, 01:02 AM   #18
Blue_TC_Man
Blue_TC_Man 25/M
Hell you like N/A you can make a killer set up. Go something like Independent throttle bodies, with 11.1 compression heads. Get some custom cam made. stroke it .30 over. port and polish. Stud the bottom end. Put a closer sync gear set in the transmission and add a 2 stage 150 shot of nitrous you'll be a mag worthy N/A that will eat a STI.
As for my setup. Probably going with a garrett turbo since they sponsor my SAE team already. Then exhaust will just be a generic log style manifold to a 3" dump to a high flow cat. with a flowmaster 30 series muffler and stock tale pipe. The exhaust will be 3" all the way back too. Probably going with a spearco IC and the garrett turbo has an internal waste gate. Probably a forge BOV might go with the 007 diverter valve to make it not so noticeable and give me alittle more power. pretty much decided on 8 PSI all the time though. Oh and i'm doing all custom piping with spectre piping
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Old 10-23-2007, 01:28 AM   #19
redrumtc
Strictly Scionized
redrumtc's Avatar
redrumtc 32/M
good job I had lite n/a my dyno is in my profile its not to bad
Sean S
Old 10-23-2007, 01:32 AM   #20
Blue_TC_Man
Blue_TC_Man 25/M
very nice numbers what was done to it?
297whp 287wtq
www.gatorz.com
www.tekbolt.com
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
