yet another retrofit headlight question...
Old Oct 25, 2007 | 05:30 PM
smilezdc's Avatar
Default yet another retrofit headlight question...
ok.. i dont think you guys are gonna like this question.. but ill ask anyways..
soo.. i dont really use my highbeam all that much; which seems to be a waste. SO the question is.. if i were to retrofit my low beams, could i throw a projector in the high beam area and rewire it so that the high beam light turns on with teh low beam...?
i would def. aim the highbeam down a bit so i dont cause car accidents on hte opposite of the high way.. but.. lemme know..
i serarched a little.. but got nothing..
THANKS IN ADVANCE
Old Oct 25, 2007 | 05:42 PM
Dakine's Avatar
Concept in Motion Crew
Probably one of the best, most professional retrofits. and yes it is possible to run dual projectors.
http://www.littodevilperformance.com...ntc/index.html
Old Oct 25, 2007 | 06:05 PM
smilezdc's Avatar
that is absolutely ridiculous! .. which is exactly what im looking for.. hahaha.. ok.. so the project begins!
Old Oct 25, 2007 | 06:50 PM
striker_1818's Avatar
U posted Larry's work! lol
he has some machinery which is how he does all his work
Old Oct 25, 2007 | 08:24 PM
chaseonbass's Avatar
That is absolutely amazing! just totally freaking amazing!!!!
Old Oct 25, 2007 | 09:49 PM
yeh he doesn't show you the aiming stages though.
Most people follow the horizontal lines on the reflector because in most cases, the reflector lines are parallel to the ground. When you know that, aiming them is easy.
How to:
- You can see the shield through the lense. So when you bolt the projector into the reflector, you align the reflector lines with the shield.
-Another way to do it is parking the car in front of the wall, lit up your halogens and mark the cutoff. Once you do that, upon mounting the projectors onto the reflector, you fire the projectors already mounted into the headlights and align the cutoff with what was previously marked on the wall. Use JB weld and you're done.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
atlantaemail
Sep 20, 2015 02:03 AM
