Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 10-30-2007, 12:10 AM   #1
SickleCell
SickleCell's Avatar
SickleCell 31/M
Default AFR Help
Can someone help me with my AFR? I'm guessing the most obvious answer is that I need a piggyback system... but I recently decided to hook my Wideband O2 sensor analog to my laptop. I did notice that my digital gauge is off by a lot. It was reading mostly from 11.3-11.9 when I had the pedal to the floor and it was reading from 12.5-12.9 at idle.
Here is a graph of a session where I was shifting first through fifth gear. I wasn't kinda lazy shifting the car to try to separate the gears as much as possible to be able to read the graph better. When I was in gear though I was flooring it, except for 1st and 2nd gear due to traction issues.
My question is, if I were running a turbo, supercharger, or spray and had this graph as my result, am I okay? Or am I running lean?
SickleCell is offline   Reply With Quote
Old 10-30-2007, 01:08 AM   #2
malloynx
malloynx 32/M
mods???
what WB are you running...
certified ford tech.
mercedes-benz master tech
ASE certified
06 scion tc
bone stock...maybe??
malloynx is offline   Reply With Quote
Old 10-30-2007, 01:25 AM   #3
SickleCell
SickleCell's Avatar
SickleCell 31/M
I'm running the Innovate Motorsports WB.
I don't have any mods that increase fuel pressure or injection.
It's really more of a question of if this were on a turbo setup, supercharger setup, or spray setup... would this be about right, lean, or rich?
Old 10-30-2007, 07:26 AM   #4
etsnet
etsnet's Avatar
etsnet 34/M
Can't really read that cuz I don't know what I'm looking at but you should be running 11.0 -11.6 WOT (pedal to the floor). You should be running about 14s at idle. Now that's if you're turbo. That's all I can tell you.
- Paul
My heart belongs to CAC and AVC
etsnet is offline   Reply With Quote
Old 10-30-2007, 11:25 AM   #5
SickleCell
SickleCell's Avatar
SickleCell 31/M
thanks for the turbo setup help. How about the other two.
the left is measuring the AFR
Old 10-30-2007, 06:05 PM   #6
Mr_Meaty
Mr_Meaty's Avatar
Mr_Meaty 37/M
Send a message via Yahoo to Mr_Meaty
Seems to me you are looking at the spikes going over 20afr. Those are probably DURING shifts. When you let off the gas, your AFRs will go thorugh the roof cause there is no gas in there, which is fine, cause your not reving your engine up.
when you are accellerating, your ARs should be in the 11s (boosted) and then as soon as you let off to slow down or whatever, your AFR will go full lean untill you slow down enough, or shift to the next gear.
that chart would be more helpfull if the bottom line was RPM or throttle or something like that.
Got boost?
Mr_Meaty is offline   Reply With Quote
Old 10-30-2007, 06:08 PM   #7
jrodTc
jrodTc's Avatar
jrodTc 32/M
Send a message via AIM to jrodTc
If i'm reading the graph correctly, it looks like 3rd and 4th gear are crazy rich while climbing thru the RPM's. It looks like it's around a 9:1 in 3rd and 4th, wow!
"Owning a 9 second neon is like coming out of the closet. At first you surprise everyone, but in the end you're still ___."
jrodTc is offline   Reply With Quote
Old 10-30-2007, 06:16 PM   #8
SickleCell
SickleCell's Avatar
SickleCell 31/M
The lowest part of the downward spike is when I pushed the clutch in before the shift, the highest part is the part when I was shifting.
It seems that when I am in gear my AFR is between 11.3 and 13.8 depending on what gear I was in.
Would an emanage (or other) be something good to use on an F/I setup to keep those numbers between 11 or 12, or am I okay with this stock setup to run the way I am?
Old 10-30-2007, 06:28 PM   #9
jrodTc
jrodTc's Avatar
jrodTc 32/M
You'll definately want to run a piggyback fuel management system of some sort to tune your AFR's. Personally, I'd say go with the AEM F/IC over the ____ty emanage.
Old 10-30-2007, 07:52 PM   #10
SickleCell
SickleCell's Avatar
SickleCell 31/M
Is that the best value?
Old 10-30-2007, 08:35 PM   #11
Mr_Meaty
Mr_Meaty's Avatar
Mr_Meaty 37/M
the emanage only does WOT. If you wanna do partial throttle, you need to also purchase the pressure sensor and the harness for that. Plus, it does not come with software, which is another $100.
the AEM F/IC comes with a built in pressure sensor and the software for $100 more then the base emanage. It is on par if not better then the emanage ultimate.
Got boost?
Old 10-30-2007, 09:17 PM   #12
SickleCell
SickleCell's Avatar
SickleCell 31/M
Do they have a PnP harness yet? I know on the site it said one was being developed.... not sure if it is out yet.
How hard is it to install?
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
